Tech Tip 1077, What Is This?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=105518
Printed Date: April 03, 2026 at 7:28 PM
Topic: Tech Tip 1077, What Is This?
Posted By: craniumvibratio
Subject: Tech Tip 1077, What Is This?
Date Posted: June 17, 2008 at 2:29 AM
I know im not the only one. I have looked for this but no one has any idea and the ones that do they tell other people that have asked confusing ways to do this. If someone could post a diagram for an 08 tacoma or what tech tip is 1077?
Posted By: fcss
Date Posted: June 17, 2008 at 9:57 AM
doc 1077 is a acc/ign isloation that u would have to do on select year altimas, celicas, echos, I have had to do it on some older xterras, the starter would grind when the car was remote started and you went to do a key take over this prvents that from happing. What you do is take the thin pink or orange from the dei remote start and put it to 85 ,86 and 87 get 12 volts, 87a goes to the key side of the acc or ign wire and 30 goes to motor side refer to the tech sheet to know which wire you will cut based on the car u are working on . Sorry but I have not done the 08 tacoma yet.
Date Posted: June 17, 2008 at 10:35 AM
I appreciate the quick response. I will see what I have to do. Do you know what the Pink/black wire is on the unit? It says its a flex relay.
Posted By: dswift
Date Posted: June 18, 2008 at 3:56 PM
igniton kill will work too. instead of doing a anti-grind or starter kill
------------- "dont ground out!"
Posted By: gus1
Date Posted: June 18, 2008 at 9:59 PM
The pink/black wire you are referring to must be on a Viper 5701, I think. What it is is the 87A or normally closed terminal of the second ignition (or "flex", as it can be programmed to be ign, accy, or start) output, with the pink/white being the 87, or normally open terminal of that relay.
For isolation purposes, then the pink/bk would go to the key side of the cut, pink/wht to the car side.
------------- Wherever I go, that is where I end up......
Date Posted: June 19, 2008 at 4:12 PM
So what you are saying is that I do not need a relay for he second starter. ( if I follow ) I think the 5701 has two ignitions and one starter and if I use the pink/bk wire the way you say I do not need a relay, I just need to program the pink/bk wire to act as a starter. I have an 08 tacoma and any experience with this truck would be a great help.
