pkg5, install in a Aztek
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=10574
Printed Date: May 14, 2026 at 4:12 PM
Topic: pkg5, install in a Aztek
Posted By: toyvet1
Subject: pkg5, install in a Aztek
Date Posted: March 08, 2003 at 12:59 AM
I am tring to install a pkg5 bypass unit in a 01 Aztek. The remote starter is a Bulldog rsa/202e. The car will remote start with the key in the ingition, but does not respond with the key removed. I have the pkg5 wired as followed in the instructions. Black from module to a black with white tracer in the car. Orange bypass to orange in car. violet bypass to violet. The brown output from bypass to RED / black "factory alarm shutdown" to remote start unit.
Posted By: jrilla
Date Posted: March 08, 2003 at 7:41 AM
The brown from the pkg5 goes to a ground out when running from your starter. You are using a factory alarm shutdown, which is designed for disarming a factory alarm, not a factory immobilizer. Factory alarm disarm (shutdown) outputs are typically only a pulsed output. What you need is a constant ground output only when the RS is running. I dont see one in the install manual, but there has to be one. If not, then you will need to use a relay to create this using an ignition output as the trigger.
J Rilla
Owner/Installer
Posted By: Velocity Motors
The BROWN wire on the PKG5 has to go to the wire that grounds out when running. This wire has to have a (-) current on it for the full duration that the remote starter is engaged and it MUST disengage when the take over procedure of the driver is started. The RED / BLACK wire that you have is only a pulsed (-) and will not work.
Date Posted: March 08, 2003 at 8:03 AM
Looks like you beat me to this post by a 1/2 second posted_image. Better two right answers then one right one .
Posted By: toyvet1
Date Posted: March 09, 2003 at 11:41 AM
Thanks guy's for the info. Called bulldog and was told what wire was a negitve output with the starter unit.Got the car up and running in no time THANKS.
Posted By: jrilla
Date Posted: March 09, 2003 at 1:42 PM
Just out of curiosity, what wire was it, because the wire diagram in the manual doesnt say what it is and thats retarded.
J Rilla
Owner/Installer
Posted By: toyvet1
Date Posted: March 09, 2003 at 5:16 PM
On the unit I have has two plug in harnesses on with 18 pins and one with three wires. the three wire harness goes to the relays. The middle wire is a white wire that is called the ingition ground he said. It is only grounded during the time the remote is working. Tested it and the unit works great now thank again..
