03 elantra doorlock problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=105797
Printed Date: March 28, 2026 at 7:40 PM
Topic: 03 elantra doorlock problem
Posted By: big sexy lac
Subject: 03 elantra doorlock problem
Date Posted: June 30, 2008 at 9:46 AM
Hey guys sorry but I'm not really sure what model avital alarm r/s it is since I didn't install it I was just asked to check it out I have only done a hand full of install of alrams and remote starts so I'm not sure how to start to trouble shoot. but here is the problem.
The door locks only work when the car is on or when it has been remote started. Any help thanks
WELL?
Posted By: KarTuneMan
Date Posted: June 30, 2008 at 10:50 AM
Where did you tag on to the locks?
Date Posted: June 30, 2008 at 11:41 AM
Actually I didn't do this install I don't kno who did but a friend of mine asked me to check it out he said they used to work fine now they don't its wierd thou the locks don't work at all when the car is off,but when its running they work at the door switch and with the remote.ohh and the alarm arms and disarms fine when the car is off but the locks don't, I'm going to start tearing into it soon to check all the connections.
WELL?
Posted By: joch1314
Date Posted: June 30, 2008 at 12:32 PM
there was just another thread with a guy who had lock problems when the car was off...but they worked when the car was on or turned in the accy position...he had to replace a fuse under the hood, and it worked after that!
I would check the fuses under the hood and make sure they all check out!  verify with a DMM and not just visually!
seems like you might have the same problem!
...half of the truth can be worse than a lie. <----Roger Russell said that..
Date Posted: June 30, 2008 at 2:44 PM
Awsome thanx guys didn't even have 2 do anything but change the dome light fuse. And I was reading that thread too but didn't catch that last posts thou.
WELL?
