need diagrams 2008 rover se
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=105831
Printed Date: May 12, 2026 at 12:30 PM
Topic: need diagrams 2008 rover se
Posted By: stevetolentino
Subject: need diagrams 2008 rover se
Date Posted: July 01, 2008 at 11:30 AM
Customer would like a remote start and thinking of using a Clifford 3.5, I would certainly appreciate it if you have diagrams an tips for install on this vehicle. Will there be a need for the customer to give up a ignition key for the bypass? Thanks again Steve
Date Posted: July 01, 2008 at 10:56 PM
Anyone????
Date Posted: July 02, 2008 at 3:14 PM
HELP!
Posted By: howie ll
Date Posted: July 02, 2008 at 4:00 PM
What is it? Disco? Freelander? Range Rover? Land Rover? What year is it?
Date Posted: July 02, 2008 at 5:26 PM
2008 Range Rover Sport SE Thanks
Posted By: howie ll
Date Posted: July 03, 2008 at 3:13 AM
Don't think you have a chance in hell, everything is hard to get at, data from ign switch, the wiring is similar to an X5 but everything about doing an alarm R/S is dificult to impossible, I did an alarm on an '02 and I even had to put an actuator in the driver's door in tandem with the factory unit because I couldn't control the locks!
Date Posted: July 04, 2008 at 12:24 AM
Anybody else have any input on this? Anyone else here done any?
Posted By: chriswallace187
Date Posted: July 04, 2008 at 12:40 AM
If howie were a bit more feminine..."no" would mean "try a different approach". However he does more weird European cars than anyone else on this site and I'm inclined to agree on this case.
Experienced as I am, I wouldn't touch that car unless I had a friend at the Land Rover dealership and complete wiring info on the car (not just the little bit that DEI supplies you). You should call DEI, talk to their tech support and ask if they've done one. Also if they have get them to fax you the pertinent diagrams for all the wires they had to connect.
Also there is no doubt in my mind the customer would be giving up a key.
------------- C Renner's Auto Electronix
