508d, 2006 mustang coupe
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=105845
Printed Date: May 12, 2026 at 9:41 AM
Topic: 508d, 2006 mustang coupe
Posted By: 2006mustangcoup
Subject: 508d, 2006 mustang coupe
Date Posted: July 01, 2008 at 7:19 PM
I have a 508D installed in my 2006 mustang coupe and it is installed in what seems to be the typical location, between the shift boot and the cup holder.
I have gotten good results from the left and right windows, but if I tilt it slightly I can get more coverage in the front of the vehicle also. Almost to the front bumber.
I have tinted windows on the sides and rear ( non metalic ) I would like to have more coverage twards the rear. The coverage becomes alot less because of the tint but if I move the sensor and lay it on the center of the back seat I get great coverage around the rear of the vehicle (bumber) and through the tint, But I loose my forward wondow and front vehicle coverage due to the sensor being two far back.
Is there a way to add a second sensor in line with the first to have one up front and one in back? Or use a free zone input?
I am also trying to understand how this unit works more to maybe help me understand some better placements as well.
I have also read some about putting the unit in the headliner and using the roof as a metalic reflective plane of some type. This would seem to be quite a hassle on this vehicle, and does this work?
Will this work for the 06 mustang?
Date Posted: July 01, 2008 at 10:12 PM
After reading through the manual more and the 508D install guide, it says that "if you are using the 508D with a dei security system that has a multiplex input, you can connect both the blue and green wires to the multiplex input".
I have the Blue H1 / 7 (-) multiplexed input zone 4 free.
Because I am using zone 1 for shock sensor and zone 2 tied into the shock sensor wireing for 508D #1 could I use the free multiplexed input zone 4 for the second 508D?
If so, from what the directions say I connect the blue and green wires to the multiplex input and the red to 12v constant and black to ground and I should be able to run two dual zone sensors seperatly?
Are there any other multiplexed inputs?
If you add a tilt sensor, is this where you would connect it?
