clifford g5 750 wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=106134
Printed Date: March 29, 2026 at 6:06 PM
Topic: clifford g5 750 wiring
Posted By: pdiddie
Subject: clifford g5 750 wiring
Date Posted: July 15, 2008 at 12:34 AM
Hello, I'm pretty new at this & need some help. I have a 94 Nissan Sentra that when I arm the the & open the door's it doesn't trigger? I wired up the H1/9 green(-) door trigger input.I believe that is the correct one.Correct me if I'm wrong,but it only give's power when the doors close. If the wiring is correct, do I use the Violet(+) for something or leave it alone.
Also how can I find the dome light trigger? Isn't that the same thing? Help !
Kind Regards,
Posted By: howie ll
Date Posted: July 15, 2008 at 11:17 AM
If your dome light goes out as soon as you shut the door , one wire should go from negative to open or pos when door closed. Conect green wire to this. If it takes about 15-20 seconds for the light to fade away, set the alarm for "courtesy light delay". Don't use the violet. Alternatively, driver's side front door pin. Should cover other door(s).
Posted By: pdiddie
Date Posted: July 15, 2008 at 6:04 PM
Hey, thanks alot I got it working!
