08 mazda 5 wiring info
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=106289
Printed Date: March 31, 2026 at 11:02 PM
Topic: 08 mazda 5 wiring info
Posted By: desh187
Subject: 08 mazda 5 wiring info
Date Posted: July 22, 2008 at 2:31 AM
Has anyone got alarm wiring info for a Mazda 5?
I have to install a factory keyless upgrade alarm on this vehicle.
Thanks.
Posted By: kola7126
Date Posted: July 22, 2008 at 7:04 AM
| MODEL | YEAR(S) | | MAZDA 5 | 2007 - |
| KEY | T-HARNESS | IMMOBILIZER | | N/A | N/A | Transponder Anti-theft requires 791 and extra ignition key (SOME MODELS) |
| PART | COLOR | LOCATION | | 12 VOLT CONSTANT | BLACK (+) AND BLACK / YELLOW (+) | IGNITION SWITCH HARNESS | | STARTER | BLACK/ BLUE (+) | IGNITION SWITCH HARNESS | | STARTER 2 | N/A | N/A | | IGNITION 1 | BLUE (+) | IGNITION SWITCH HARNESS | | IGNITION 2 | N/A | N/A | | IGNITION 3 | N/A | N/A | | ACCESSORY /HEATER BLOWER 1 | BLACK/ RED (+) | IGNITION SWITCH HARNESS | | ACCESSORY /HEATER BLOWER 2 | BLACK/ BLUE (+) | IGNITION SWITCH HARNESS | | KEYSENSE | WHITE/ BLUE (-) | IGNITION SWITCH HARNESS | | PARKING LIGHTS ( - ) | N/A | N/A | | PARKING LIGHTS ( + ) | GRAY/BLACK (+) | LOW IN DRIVERS KICK PANEL | | POWER LOCK | BLUE (-) SEE NOTE * | SEE DIAGRAM | | POWER UNLOCK | SAME AS LOCK WIRE | SEE DIAGRAM | | DOOR TRIGGER | SEE NOTE ** | AT BCM LOCATED BELOW GLOVE BOX | | DOMELIGHT SUPERVISION | USE ANY DOOR TRIGGER | | | TRUNK RELEASE | N/A | N/A | | SLIDING POWER DOOR | N/A | N/A | | HORN | VIOLET/WHITE (-) | AT STEERING COLUMN HARNESS | | TACH | BLACK / YELLOW | AT ECM ON DRIVERS SIDE OF ENGINE COMPARTMENT | | WAIT TO START LIGHT | N/A | N/A | | BRAKE | GREEN/ YELLOW (+) | AT SWITCH ABOVE BRAKE PEDAL | | FACTORY ALARM DISARM | LIGHT GREEN/ RED (-) | IN DRIVERS KICK PANEL | | ANTI-THEFT | TRANSPONDER ANTI-THEFT | TRANSPONDER @ IGNITION SWITCH TUMBLER |
| EXTRA INFORMATION | | NOTE * THIS VEHICLE HAS SINGLE WIRE DOORLOCKS AND WILL REQUIRE EXTRA PARTS. SEE DIAGRAM. NOTE ** THE LEFT FRONT DOOR IS BLUE/BLACK (-). THE RIGHT FRONT DOOR IS RED / YELLOW (-). THE LEFT REAR DOOR IS GREEN/ ORANGE (-). THE RIGHT REAR DOOR IS GREEN/ ORANGE (-). USE ALL 4 WIRES AND DIODE ISOLATE EACH. |
