do i need imobilizer/bypass 94 explorer
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=106323
Printed Date: March 31, 2026 at 12:39 AM
Topic: do i need imobilizer/bypass 94 explorer
Posted By: csb41502
Subject: do i need imobilizer/bypass 94 explorer
Date Posted: July 23, 2008 at 4:08 PM
im not sure if my explorer xlt has a factory alarm or if i need a bypass of any sort.how do i know if i have a factory alarm?i dont know if i need to disarm it with my 791.and do i need any kind of bypass?
Posted By: fcss
Date Posted: July 23, 2008 at 6:38 PM
in a 94 explorer there is no chip in the key so you dont need a bypass, to test for a factory alarm with the dr door open and window down hit lock on the dr door switch then close the door wait a few minutes then open the door from the inside handle if the horn goes off then there is a factory alarm if nothing then you are good. Im not sure but with the door locked and closed the car might have a security or theft light in the cluster that blinks to tell you if there is a alarm but I would do the test.
The disarm wire if there is a alarm is dk.GREEN/ purple (-) in dr kick so you would use the GREEN/ black (disarm) wire on the Dei 791 to disarm it
