keyless problem in a cop car
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=106446
Printed Date: March 29, 2026 at 10:15 PM
Topic: keyless problem in a cop car
Posted By: audioinstaller3
Subject: keyless problem in a cop car
Date Posted: July 29, 2008 at 9:50 PM
I just put a autopage keyless entry in 08 ford crown vic..cop car. Everything works, but the cop needed to be able to lock and unlock it with the car running. So I disconnected the ignition wire to allow this, but now the led doesn't work. Does the ignition wire need to be hooked up in order for the led to work or no? Any ideas, if it does need to be attached, how to go about letting the car lock and unlock whether its running or not? Thanks.
Posted By: chriswallace187
Date Posted: July 30, 2008 at 12:31 PM
The ignition probably is necessary for LED and programming purposes - you could probably just wire a toggle switch inline on it to turn it off when the cop needs to get out and lock with it running.
------------- C Renner's Auto Electronix
Date Posted: July 30, 2008 at 9:27 PM
Ya I thought about that, but if the cop needs to bail out of his car in a hurry..hes doesn't need to worry about switching a toggle switch every time he bails out of his cruiser. So I just left it disconnected. Any ideas how to hook up the led another way to work with the ignition wire disconnected?
Date Posted: July 31, 2008 at 12:10 PM
I'm having a hard time understanding why the LED is important at all? If you just needed the ignition for programming, you could substitute "normally open momentary switch" for "toggle switch" in my previous post.
Date Posted: July 31, 2008 at 5:31 PM
Ya I guess its not really important. The cop just wanted it to work, but without the ignition it won't work I guess, and hooking up a toggle switch would be pointless. Thanks for the reply though.
