motion tek 8000 r in 2001 f150
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=106470
Printed Date: March 30, 2026 at 6:29 AM
Topic: motion tek 8000 r in 2001 f150
Posted By: mbswisha60
Subject: motion tek 8000 r in 2001 f150
Date Posted: July 30, 2008 at 5:35 PM
i just bought a remote start alarm (motion tek 8000-r). does anybody know what equipment i need and how to install it. please help.
Date Posted: July 30, 2008 at 5:42 PM
i need help installing a motion tek 8000-r in a 2001 ford f150.if anybody knows please help.thanks
Posted By: i am an idiot
Date Posted: July 30, 2008 at 7:30 PM
Which part of the install do you have figured out?
Date Posted: July 30, 2008 at 10:18 PM
i installed the alram already. but i am having trouble with the remote starter. the truck does not turn on completely, i press the button and the engine turns on but then real quick it turns off.
Date Posted: July 30, 2008 at 10:25 PM
What color wires on the vehicle did you connect to the remote start unit?
Did you connect all of the following wires? If not, which ones did you not connect?
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|yellow & lt. grn/pur|+ |ignition harness            |
|          STARTER|RED / lt. blue        |+ |ignition harness            |
|        IGNITION|dk. blue/lt. green |+ |ignition harness            |
| SECOND IGNITION|gray / YELLOW        |+ |ignition harness            |
|   THIRD IGNITION|lt. blue/pink *1    |+ |ignition harness            |
|        ACCESSORY|RED / black           |+ |ignition harness            |
| SECOND ACCESSORY|BLACK/ green        |+ |ignition harness
Date Posted: July 30, 2008 at 10:33 PM
i took it to a alarm installer but he did not make it work. can u tell me all the connections that u know about it so he can fix the problem. thanks for helpin
Date Posted: July 30, 2008 at 10:38 PM
You might want to rethink your choice of shops at this point.
On my last post are all of the wires that are required to remote start the vehicle. The following link includes all of the wires that I know about for putting an alarm in that vehicle.
Look Here Make sure you read the notes at the end of the wiring info.
