viper 5900 failure mode
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=106588
Printed Date: April 18, 2026 at 8:45 AM
Topic: viper 5900 failure mode
Posted By: propstm
Subject: viper 5900 failure mode
Date Posted: August 05, 2008 at 3:42 PM
Hello, I am installing a Viper 5900 in my 2003 Ford Excursion. I just want to verify the operation of the alarm if the unit fails/loses power etc.
If I cut the starter wire, and wire the purple wire coming from the remote start to the starter side, and the green wire to the key side of the starter wire and the Viper fails, from what I understand, the truck will not start, even with the key. Is this correct?
Thanks for the help.
Posted By: megaman
Date Posted: August 05, 2008 at 4:03 PM
no it's not correct. The relay is normally closed connection. So if the system fails you will still be able to start your vehicle with your key. The only time the starter is interupted is while the alarm is armed, or it is remote started (anti-grind option on).
Posted By: propstm
Date Posted: August 05, 2008 at 4:06 PM
Thank you, I appreciate the help.
Posted By: propstm
Date Posted: August 09, 2008 at 3:35 PM
Hi, I have another question on this install. I installed the system today and am testing the remote start. The Excursion is a diesel, so I am using the timer method for waiting enough time for the start.
The truck starts fine, and the safety features(hood pin/Brake) work fine. The truck also runs fine if I put the key in the ignition and drive.
When the truck is in remote start mode, and running, but I haven't put the key in the run position, I can here relay's clicking in the Viper every 10 seconds or so. Is this normal.
Posted By: megaman
Date Posted: August 09, 2008 at 4:30 PM
Yes, that's the internal relay controlling the parking light flash. You can change the flashing output to constant through the programming.
Posted By: propstm
Date Posted: August 09, 2008 at 5:03 PM
Ah, I appreciate that, I must have missed that, and I have hooked up the entire unit yet.
Thaks
