adding a siren to a factory alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=106599
Printed Date: April 18, 2026 at 8:30 AM
Topic: adding a siren to a factory alarm
Posted By: Jaice
Subject: adding a siren to a factory alarm
Date Posted: August 06, 2008 at 11:36 AM
I have a 2005 Chevy Impala LS with the factory alarm. I was wanting to add an aftermarket siren to it, so when the alarm sounds, it will horn honk and siren. I'm sure the factory is all set up through the bcm so it tells the horn to sound, I could be worng. Does anyone have any suggestions? The only one I could think of as wire the siren up with the horn in the front, it might work, only drawback is when I press the horn it will siren also, would this work?
Posted By: KPierson
Date Posted: August 06, 2008 at 3:49 PM
Your best bet would be to find the wiring diagram for the alarm system.  Some cars have seperate circuits for the alarm horn output and the steering wheel horn output, but some cars use the same circuit.
If it does use the same circuit you could wire a relay up to prevent the siren from sounding if the ignition is on - that might be good enough.  You may also be able to tap in to the steering wheel horn switch (most are low current (-) signals that drive relays or BCMs) and prevent the siren from sounding whenever the steering wheel horn switch is pushed down.
Kevin Pierson
Posted By: hurleyloser
Date Posted: August 07, 2008 at 3:57 AM
the previous post is an easy enough solution, you can also try adding a capicitor to the siren to keep it on during the gaps in the horn honks so as the horn is honking, the siren remains constant throughout. There's a diagram on here for cornering lights (to turn on and stay on with intermitent turn signal) that should work for this.
MECP Master Certified Technician
ASE A6 Certified Technician
