wiring information on grand suzuki vitara
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=106741
Printed Date: May 11, 2026 at 9:53 PM
Topic: wiring information on grand suzuki vitara
Posted By: gremechar
Subject: wiring information on grand suzuki vitara
Date Posted: August 13, 2008 at 5:34 AM
I need to install an automate am1 in a suzuki grand vitara 2007 - 4 dr suv. Does anyone have the wiring instollogy for the vitara?
Posted By: fcss
Date Posted: August 15, 2008 at 7:00 PM
Im in the states and I just did one of these is what i have hope it is the same
12 Volts WHITE/ red and whitegreen
Starter BLACK / YELLOW
Ignition BLACK / YELLOW also
at ign harness
Lock Motor blue/red
Unlock Motor pink/green
2nd Unlock Motor blue / YELLOW
in dr kick at bcm which is high in the dr kick
Parking Lights (-) at switch
Parking Lights (+) RED / yellow in dr kick harness going towards rear
Left Front Door Trigger BLACK/ orange(-)
Right Front Door Trigger blacr/red (-)
Trunk Pin tied into pass dr trigger
at bcm in dr kick
Horn Trigger (-) blue at horn switch harness
An am1 is an upgrade alarm to factory remotes correct this should be all you need I did an alarm remote start so I have r/s wiring notes to if you need them
Date Posted: August 31, 2008 at 9:45 PM
thx again. it all worked well. had a defective valet switch which gave me some headache but that's resolved now
