astro flex model 800
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=106818
Printed Date: May 12, 2026 at 11:33 AM
Topic: astro flex model 800
Posted By: chev104275
Subject: astro flex model 800
Date Posted: August 16, 2008 at 7:01 AM
as stated in the subject i have a customer with a astro flex model 800 remote start in his 94 escort   does anybody have the programming data for this kit   im looking to program the remote and tach   thanks in advance Joe
Posted By: KarTuneMan
Date Posted: August 16, 2008 at 8:22 PM
Joe. Determin what series 800 (801,802,803) and PM me you email address, I'll send you an install guide!
If you can read the part # off the brain that would do it as well.
Date Posted: August 18, 2008 at 12:01 PM
I should have paid closer attention. To reprogram a remote, first have ALL of them, cause when you do one you need to relearn them all.
Flip dip# 8 up, step on the foot brake, push unlock on each remote (you should hear the brain "click") put dip# 8 down, step on the foot brake. Done!
The tach make sure the engine is warm first.  Put dips 1 5,6,7 up, start the car with the key and after it starts, step on the foot brake you again will hear the brain and the lights will flash. when its done makin noise shut the car off, put all the dips down and hit the brake!
