2006 explorer alarm diodes needed?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=106853
Printed Date: May 12, 2026 at 11:33 AM
Topic: 2006 explorer alarm diodes needed?
Posted By: bluecobraclone
Subject: 2006 explorer alarm diodes needed?
Date Posted: August 17, 2008 at 10:54 PM
Hello,
I'm about to install a Code Alarm CA 680 into my 06 Ford Explorer. I've been reading about the need for diodes to be installed on the door lock/unlock outputs.
This unit has negative outputs for the lock/unlock wire, which I've read to be a direct connect. But i've been doing some reading on this site that says you need to install diodes on the lock/unlock outputs to allow the security module to go to sleep, otherwise I'll get a battery drain problem. I had this unit installed on my 05 F150 and always saw that the battery was draining after sitting for a couple weeks and could never figure out why.
Can someone please elaborate on what i need do do? i.e. what diodes do i need to buy, and how do I install them? is it simply inline between the alarm and the vehicle wiring?
Thanks!
Posted By: KarTuneMan
Date Posted: August 18, 2008 at 1:31 AM
You can trigger YELLOW /GREEN, AND PURPLE / green, in the drivers kick (isolating with diodes) this will arm and lock factory security.
unlock is PURPLE / gray in the drivers running board... negative trigger. you should not have a BCM problem....
Posted By: howie ll
Date Posted: August 18, 2008 at 2:35 AM
The BCM goes to sleep NOT the alarm, you need to look at DEI 1076 diagramme, it's here somewhere, problems on the previous vehicle were not alarm related, a correctly wired alarm well add about 30mamps draw to the battery.
Posted By: i am an idiot
Date Posted: August 18, 2008 at 5:06 AM
