97 toyota rav 4, tach connection
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=106971
Printed Date: May 12, 2026 at 5:12 AM
Topic: 97 toyota rav 4, tach connection
Posted By: maxcat
Subject: 97 toyota rav 4, tach connection
Date Posted: August 22, 2008 at 10:37 PM
Hey guys, currently working on a 97 toyota rav 4. my information says the tach wire is a blue/white or a black\white at the coil. can someone verify this is correct, and if so where is the exact location of the coil.
          thank-you in advance
Posted By: i am an idiot
Date Posted: August 22, 2008 at 10:48 PM
The info I have says BLACK/ white. If this vehicle has a classic distributor/coil setup, the spark plug wires go to the distributor. There is another plug wire looking wire on the distributor that goes to the coil.
Some vehicles have the coil built into the distributor.
Posted By: howie ll
Date Posted: August 25, 2008 at 7:09 PM
More likely an injector port, look at the 8 wires, 4 will be the same colour, 4 will be different, one the different ones, or may be some wires from the distributor, if you find one, check wires from this unit,  last some Toyotas and all Lexus have a BLACK/ silver dots on the OBD II socket under driver dash.
