05 isuzu aderscen door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=107073
Printed Date: May 12, 2026 at 1:22 AM
Topic: 05 isuzu aderscen door locks
Posted By: kondziolka
Subject: 05 isuzu aderscen door locks
Date Posted: August 27, 2008 at 2:39 PM
Hello, I am trying to find a copy of directfax document #1053. Thanks in advance.
------------- Where ever there is a problem there is opportunity.
Posted By: Chris Luongo
Date Posted: August 27, 2008 at 6:09 PM
You'd be there half a day with that document, and you'd still end up missing a lot of the factory features.
www.idatalink.com
www.ifar.ca
www.bypasskit.com
All of those three companies make databus modules that'll do the door locks for you.
All three have the installation manuals online too, so you can see how it's done before you buy.
Date Posted: August 27, 2008 at 11:16 PM
Thanks Chris I'll check those out. I still woul like to see the document if anyone has it. I may not have the money in this customers budget for a mod.
Date Posted: August 28, 2008 at 6:25 AM
Maybe someone here can find the module for you.
From what I remember, it goes like this:
1. Run wires into driver's door, configure two relays, connect driver's doorlock motor as 5-wire.
2. Repeat this, inside passenger door.
3. Repeat this, inside tailgate.
4. Run factory-disarm wire inside driver's door. (No way to arm the factory alarm, all you can do is disarm.)
5. Run wires underneath the rear seat, where you can find regular wires to lock and unlock the two rear doors.
