command start replacement remote starter
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=107344
Printed Date: March 28, 2026 at 1:19 PM
Topic: command start replacement remote starter
Posted By: kingchip13
Subject: command start replacement remote starter
Date Posted: September 09, 2008 at 10:14 PM
I purchased a 1997 jeep grand cherokee about a year ago and just noticed that it came with a Command Start remote cat starter. Problem it dident come with the remote!!?? I've tired to search the internet and i keep comming to the same Asroflex dead end. I even called around to the local business that install these kinds of things and they have never heard of the brand... If anyone knows about this brand and has an idea of where I could buy a replace remote please let me know.
Sincerely,
Your average penny pincher
Steven Sandman
Posted By: saskpuller
Date Posted: September 13, 2008 at 11:13 AM
I found them at a wholesaler up here in Canda and I keep them in stock. The cat # is CS-560. Not sure if you can find that somewhere in SD. Honestly pull the POS out and put in a newer unit. The remote will run you 30-50 and a new unit about $100.
Posted By: Velocity Motors
Date Posted: September 14, 2008 at 9:33 AM
You need to find the CPU model number. Not all Command Starts use the same remote control and you will need to find out which one is the
proper one to buy before getting one.
