speaker foam baffles
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=107393
Printed Date: May 12, 2026 at 12:23 AM
Topic: speaker foam baffles
Posted By: still_walkin
Subject: speaker foam baffles
Date Posted: September 12, 2008 at 7:56 AM
i was wondering do they still sell those speaker foam baffles that you can mount under the speaker to drown out the surrounding noise. the porblem is when my bass is up my subs are forcing air against my 6x9s and i was wondering if there is another option to fix this thanks again
1993 sdv
Alpine 4x6 6x9 5 1/4 swr-10d4
alpine v60
12.5 VGA flip down
Nettop pc w/10" touch screen
78nova
5-re audio 5x7 ,10" sub &
Xtx-500.5
Posted By: megaman
Date Posted: September 12, 2008 at 9:11 AM
foam baffles will not help in your situation.  I assume you've got some bass in the trunk and your rear 6x9's are feeling the force?  If you want to isolate the 6x9's you'll have to put them in a solidly built box, whether fiberglass or other material.
Date Posted: September 12, 2008 at 9:44 AM
I can use the factory 6x9 covers but I doubt they'll fit my trunk setup I need to go measure . The stock enclosures are fiberglass
1993 sdv
alpine v60
12.5 VGA flip down
78nova
Xtx-500.5
Posted By: Hornshockey
Date Posted: September 12, 2008 at 11:01 AM
Metra makes a plastic 6"x9" speaker baffle if you want to check that out, their part # is 81-6900.  It's a stiff plastic, not the foam XTC ones that I think you're thinking of.  I'm sure there are other maufacturers out there making something similar as well.
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
Date Posted: September 12, 2008 at 3:18 PM
A link would help
1993 sdv
alpine v60
12.5 VGA flip down
78nova
Xtx-500.5
Date Posted: September 12, 2008 at 4:20 PM
https://www.google.com   posted_image
Posted By: ncchance
Date Posted: October 07, 2008 at 1:13 PM
Haha! Nice!
