Compustar
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=10741
Printed Date: April 24, 2026 at 5:16 PM
Topic: Compustar
Posted By: DMookie
Subject: Compustar
Date Posted: March 11, 2003 at 12:35 PM
Hey I just had a compustar alarm installed on my 1996 Cavalier Coupe. I now have a small problem. I noticed just recently that the dome light is staying on. It's not staying on all the way, just half way. Kinda half fillament lighting. I was told this could be the diodes by the door pins. Can someone direct me a little better on what to look for? I mean say it IS the diodes, how will I know, or what should I do? If someone can help me out here that would be great.
Posted By: wiremadness
Date Posted: March 12, 2003 at 8:17 PM
A very common problem on Chevys is the door pins themselves. Try removeing the driver's door pinswitch & disconnect both wires. (Should be white & tan).  If this cures the problem, replace the switch.
If not, then reassemble the switch, reinstall.  Disconnect the alarm door trigger wire & see if problem persists.
Good luck!
Chris
Store Manager
Posted By: shawoo
Date Posted: March 14, 2003 at 8:30 AM
Let me know how that compustar system works. The place i went to said that those units have a lot of troubles (the pager systems)...i wanted one really bad, but in the end i just went to cc and got the audiovox system installed.
Posted By: DMookie
Date Posted: March 14, 2003 at 2:49 PM
So far I love it. Just need to get this fixed then, I'll tell ya more.
Posted By: dman007
Date Posted: May 16, 2003 at 8:00 PM
Just finished installing 2wss-as in my RSX and its stuck in valet mode, pressing I and III doesnt do anything. It only locks and unlocks, any help?
Posted By: securinu
Date Posted: May 16, 2003 at 9:10 PM
Yeah pull it out and get an alarm that will work compustar suxs ass... they cost me over $10gs in bad units that continually fail.  get rid of it while you can....
Joe O'Byrne
Owner / Installer
Posted By: Jeffqb11
Date Posted: June 03, 2003 at 8:42 PM
Hey am having a problem with mine. The pager will only lock and unlock my doors but other than that it works great. I took it back to the dealer and they had to send off the brain back to compustar. How would you go about returning it? I had it in my car a week before it was sent back and that was a month ago.
Posted By: mrmusic
Date Posted: June 05, 2003 at 12:06 AM
I just Installed on In my 2003 Ford E350 SD diesel Van
It was All that Bad The hardest Part Was trying to find how to hook it up  with No wiring lay out. I will be Posting what I found and How It gets hooked Up Tomarrow..
                Chris
Chris
Jackson NJ
