2008 tacoma tx rx data wires?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=107519
Printed Date: May 07, 2026 at 12:08 AM
Topic: 2008 tacoma tx rx data wires?
Posted By: scalin6
Subject: 2008 tacoma tx rx data wires?
Date Posted: September 17, 2008 at 7:25 PM
I have a Key-Override-All from Fortin, and i want to install it in a 2008 Tacoma.I could not find anywhere informations about Rx(data in), Tx(data out).
Where can i find these wires in the truck, and what colors are they?
And one more thing, the blue wire, (-) while running, that has to be connected to a (-) output from alarm?
Thank you Calin.
Posted By: StealthEs
Date Posted: September 17, 2008 at 10:36 PM
https://www.idatalink.com/installguide.php
Last one on the list
Go to the link and youll see the wires you are looking for. I know its not the Fortin directions but itll show you what you need.
Cris
Posted By: kgerry
Date Posted: September 18, 2008 at 10:52 AM
if you go to BypassKits website and look up the vehicle in question.. it will give you a list of modules that will work... then open the install guide for those modules and they usually give you all the wiring info you need... wire colors, etc...  as if you were using their module.... thats often what i do....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: enice
Date Posted: September 18, 2008 at 11:08 AM
Its easy.....on the manual it tells you that its pin 4 and 5....PIN #3 is EMPTY.  Therefore the next pin is 4 and then 5.  Count from where pin 3 is empty for you.  Its as simple as that.
Posted By: scalin6
Date Posted: September 18, 2008 at 3:09 PM
Thank you for your answers, Calin.
