remote start autocommand 25622
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=107583
Printed Date: May 07, 2026 at 5:11 AM
Topic: remote start autocommand 25622
Posted By: robus
Subject: remote start autocommand 25622
Date Posted: September 20, 2008 at 11:23 PM
I installed AutoCommand remote start model 25622 in my 04 Galant GTS.
This is the type which uses factory remote. It went pretty easy, except remote start activation. Remote works when I touch the ground with remote start wire.
It needs negative pulse to activate. I would like to use unlock (2x). I have no clue where to look for the actual open door signal.
Does anybody have an idea what should I do?
Thanks in advance.
Rob
Posted By: i am an idiot
Date Posted: September 21, 2008 at 1:48 AM
posted_imagePower UnlockLT.GREEN/ RED(-)
AT THE ETACS MOD
The ETACS module is located behind the fusebox.  It does not say whether it is in the car or in the engine compartment.
Posted By: robus
Date Posted: September 21, 2008 at 8:36 AM
I am looking for an output not input. Lt GREEN/ Red wire will open my doors. This wire doesn't change state when doors are being activated.
Posted By: robus
Date Posted: September 21, 2008 at 1:24 PM
OK, I figure it out.
Using positive impulse from unlock wire to my door actuator and converting it to negative by using relay.
Rob
Posted By: chriswallace187
Date Posted: September 21, 2008 at 1:39 PM
Good job! I was just getting ready to post that.
C Renner's Auto Electronix
