08 toyota sequoia, remote starter
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=107678
Printed Date: March 28, 2026 at 3:34 PM
Topic: 08 toyota sequoia, remote starter
Posted By: bubba-b
Subject: 08 toyota sequoia, remote starter
Date Posted: September 24, 2008 at 8:45 PM
i just try to put a starter in a 08 tou sequoia and the remote start i put in will only run 8-10s then shut down,,this is w/ the key in the ign..any thoughts..thanks
------------- Dazed and confuzalized
Posted By: StealthEs
Date Posted: September 24, 2008 at 9:14 PM
Sounds like a bad tach wire.
------------- Cris
Posted By: bubba-b
Date Posted: October 05, 2008 at 11:25 AM
does anyone know lock & unlock & factory disarm on a 08 toyota seqoia
Date Posted: October 06, 2008 at 12:08 PM
| Power Lock | red | - | pass kick or fuse box, white 66 pin plug, pin 49 | | This wire will test with the passenger door power lock switch. This wire is only needed if the power locks do not function during remote start or ignition locks. All other times just use the factory alarm arm wire. |
| | Power Unlock | white | - | pass kick or fuse box, white 66 pin plug, pin 40 | | This wire will test with the passenger door power lock switch. This wire is only needed if the power locks do not function during remote start or ignition locks. All other times just use the factory alarm disarm wire. |
------------- Cris
Date Posted: October 06, 2008 at 12:09 PM
| Factory Alarm Arm | lt. blue to purple | - | driver kick or fuse box, white 66 pin plug, pin 53 | | Meter this wire while turning the key in the driver door key cylinder. This wire will also lock the doors. |
| | Factory Alarm Disarm | pink to black | - | driver kick or Body ECU, white 26 pin plug, pin 10 | | Meter this wire while turning the key in the driver door key cylinder. This wire will also unlock the doors with a double pulse. The Body ECU is attached to the fuse box, under the driver side dash. |
------------- Cris
Posted By: albertatech
Date Posted: October 15, 2008 at 4:30 PM
Not my topic but kudos anyway, was trying to do a Viper 5701 in one of these without any more info than ignition, acc, starter wires. Didnt even have my bitwriter updated for that module and had to program with the button and light. Managed to get everything else, fairly standard that. Didnt feel too good about shirting out something so when I realized locks werent what I expected I had to back off a bit. Again, thanks.  RANT: You know what else is helpful? The customer trying to sit in the driver seat while you are working.
Date Posted: October 15, 2008 at 4:41 PM
How are the door pins connected? Preferably I would like to connect to them all at one place so I dont have to run to each door separately. I imagine they are probably close to the lock wires but Im not sure which. P.S. - I am unsure if Bubba is done his unit, probably, but this seemed the place to add my question, to keep it all together.
Posted By: Mike M2
Date Posted: October 15, 2008 at 6:05 PM
You can use the gray keysense wire to disarm without unlocking the doors. For door trigger, go to the light on the key cylinder. It will do all doors... ------------- Mike M2
Tech Manager
CS Dealer Services
Posted By: bubba-b
Date Posted: October 16, 2008 at 9:04 PM
when refering to factory arm as lt blue to purple, what does that mean...i have looked in drvs kick and can not find arm or disarm any help is much appreciated
Date Posted: October 16, 2008 at 9:26 PM
it will be one color on one side of the plug and another on the other.
white 66 pin plug, pin 5, find that plug at the fuse box or go looking in the drivers kick panel and your set.
------------- Cris
