compustar pro900fm, 03 accord problems
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=107711
Printed Date: April 23, 2026 at 2:52 AM
Topic: compustar pro900fm, 03 accord problems
Posted By: jbody
Subject: compustar pro900fm, 03 accord problems
Date Posted: September 25, 2008 at 9:20 PM
first thing, i have everything hooked up.
i used an idatalink ADS-DL for the bypass.
when i go to remote start it takes about a minute before the compustar tries to crank, if i have the clutch in, when it starts to crank, it'll turn over, but don't know why its taking almost a minute before it attempts to start the car.
also. need help with clutch bypass
two color wires = blue and black.
tried using the status out (black) wire on compustar and attached to blue, but no dice as well as black.
if anybody can help me out, mainly the start attempt taking a while. id appreciate it. along with clutch bypass.
v6 2003 honda accord 6spd.
Posted By: i am an idiot
Date Posted: September 25, 2008 at 9:40 PM
I am not familiar with your alarm or remote start unit, could it have a wait to start feature for diesel vehicles? A minute seems kind of long, but it is just a thought.
Posted By: jbody
Date Posted: September 25, 2008 at 9:51 PM
whoa really?
this is a really common alarm
the brain is a CM4300
Compustar PRO900FMR
Date Posted: September 25, 2008 at 9:58 PM
It has been nearly 20 years since I have done an install.
Posted By: jbody
Date Posted: September 25, 2008 at 10:00 PM
oh that would explain why :p
Posted By: jbody
Date Posted: September 25, 2008 at 10:34 PM
okay clutch bypass has been fixed.
i just don't understand why its taking a while before it starts up.
Posted By: extreme1
Date Posted: September 25, 2008 at 11:02 PM
it's set to diesel wait to start mode.
You need a programmer to change it.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Posted By: jbody
Date Posted: September 25, 2008 at 11:03 PM
i have a compustar pro900fmr.
autostart works however, it takes approximately a minute before it even tries to crank, all instrument lights are on inside, but it will crank about a minute after you engaged the auto-start
using iDatalink ADS-DL to control bypass and factory alarm.
Date Posted: September 26, 2008 at 3:59 AM
Posted By: jbody
Date Posted: September 26, 2008 at 11:33 PM
its odd. i used my other brain which isn't programed to "diesel" mode, and its doing the same thing, any suggestions?
