viper 771vx in a prelude 01
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=107738
Printed Date: April 22, 2026 at 11:33 AM
Topic: viper 771vx in a prelude 01
Posted By: bmxfreak415boy
Subject: viper 771vx in a prelude 01
Date Posted: September 26, 2008 at 10:13 PM
hey guys im new to this site what do i need to do to install this alarm system with remote start?? any diagrams or anything that i can get helped with?thanks
Posted By: i am an idiot
Date Posted: September 27, 2008 at 3:36 AM
Battery WHITE (+) IGNITION SWITCH HARNESS
Ignition 1 BLACK / YELLOW (+) IGNITION SWITCH HARNESS
Ignition 2 WHITE/ BLACK (+) IGNITION SWITCH HARNESS
Accessory 1 YELLOW (+) IGNITION SWITCH HARNESS
Starter 1 BLACK/ RED (+) IGNITION SWITCH HARNESS
Anti-Theft Type RF ACTIVATED SYS.
Anti-Theft Descript TRANSPONDER
Key Sense BLUE/WHITE (-) STEERING COLUMN HARNESS
Neutral Safety BLUE/WHITE (-) GEAR SELECT SWITCH
Tachometer BLUE (-) PASS STRUT TOWER 2 PIN PLUG
Speed Sense BLUE/WHITE (AC) AT ECM
Parking Lights RED / BLACK (+) EMPTY SLOT FUSE BOX OR SEE NOTE
Brake Lights WHITE/ BLACK (+) OR GRN/WHT SWITCH AT BRAKE PEDAL
Reverse Lights GREEN/ BLACK \ (+) RELAY ABOVE FUSE BOX
Horn BLUE/RED (-) STEERING COLUMN HARNESS
ECM located under front passenger footrest.
All Door Trigger BLACK/ WHITE (-) FACTORY ALARM CONNECTOR ABOVE PEDALS
Trunk Trigger ORANGE / SIL DOT. (-) DRIVERS KICK PANEL
