2 cars on one remote, clifford 12.5x
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=107811
Printed Date: April 19, 2026 at 12:12 AM
Topic: 2 cars on one remote, clifford 12.5x
Posted By: dirteeboy808
Subject: 2 cars on one remote, clifford 12.5x
Date Posted: September 30, 2008 at 1:06 AM
The complete question is, how to install (2) cars on one 2-way LCD remote for a Clifford 12.5x alarm system?
I recently installed a Clifford 12.5x on a new vehicle just purchased and it just so happens that I the same alarm on another vehicle I own...
thanksposted_image posted_image
It probably doesn't matter, but the 2 vehicles are a 2008 Ford F350 and a 1995 Nissan 240sx
Posted By: douglas.dixon3
Date Posted: September 30, 2008 at 7:08 AM
look in the instruction manuel,  you just need to program the remote to both brains
Date Posted: September 30, 2008 at 11:33 AM
just switch the vehicle # for the other cars accordingly and reprogram as if the remote forgot car it came from, right?
Posted By: offroadzj
Date Posted: September 30, 2008 at 1:15 PM
The downside to doing it that way is that if both cars are within range, you will control both cars. Another way to do it is to manually program each vehicle to a different button (you will use up your auxilary buttons though). This way each button will control different functions on each vehicle.
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Date Posted: September 30, 2008 at 1:34 PM
Wouldn't each vehicle have it's own vehicle number <ie-the vehicle number listed on the side of the remote 1-4>, so each vehicle frequency or however signal is projected be different than the other
Date Posted: October 06, 2008 at 12:01 AM
anyone got any ideas or solutions?
Posted By: jar754
Date Posted: October 06, 2008 at 9:06 AM
you can control both cars without setting the other one off, you just have to select car #1 or #2 on the remote. read your manual as it has the intstructions
Posted By: jar754
Date Posted: October 06, 2008 at 9:09 AM
i believe you can control up to 4 different cars with 1 remote for a max of 4 remotes per car
Date Posted: October 06, 2008 at 11:25 AM
I've been through the manual many times and it doesn't say how to do it....=(
