2009 mbz r350v4 diagram needed
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=107902
Printed Date: March 28, 2026 at 7:27 AM
Topic: 2009 mbz r350v4 diagram needed
Posted By: stevetolentino
Subject: 2009 mbz r350v4 diagram needed
Date Posted: October 03, 2008 at 11:10 AM
I got a new assignment, I need to find a diagram that shows where the starter circuit is to interrupt it with a  starter kill.  Can anyone help?
Posted By: howie ll
Date Posted: October 03, 2008 at 2:24 PM
On the saloons look for underhood fuse box drivers side, 1 plug at the end carries a wire with a PURPLE main colour. This should also apply to the R series since the basic electrics are the same on all models and Chrysler Crossfire. Test the purple it should only give 12v+ on cranking. N.B. It's the only safe place to cut as anywhere near ign switch will be data/CAN which is self  testing, thus all sorts of problems, warning lights and fault codes. It's the only SAFE place to cut the starter.
Date Posted: October 03, 2008 at 2:38 PM
Thanks Howie, you always seem to come through.
Posted By: KPierson
Date Posted: October 03, 2008 at 4:07 PM
Maybe I should have stayed in the business a bit longer, sounds like a fun car to work on!    :)
Kevin Pierson
Date Posted: October 03, 2008 at 5:15 PM
Any other input on this particular vehicle or someone who has done one?  Speak up!posted_image
Date Posted: October 11, 2008 at 9:53 PM
anybody?
