multiple problems on 2002 tahoe
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=107914
Printed Date: May 12, 2026 at 1:22 AM
Topic: multiple problems on 2002 tahoe
Posted By: guccicrew100
Subject: multiple problems on 2002 tahoe
Date Posted: October 04, 2008 at 12:41 AM
2002 chevy tahoe,DesignTech 20092,GM 555L bypass.starter engages too long .Runs for about 30 sec,shuts off then restarts.Serious problems with the door locks tahoe had been broken into and deck stolen bunch of open wires.on first contact of lock wire to power will activate but not again evan with switch unless started and in gear then only drivers side.Help this install is very important to me.thanks
guccicrew100
Posted By: chriswallace187
Date Posted: October 05, 2008 at 12:08 AM
For the starter - it sounds like you haven't programmed the tach correctly.
For the locks - elaborate on how exactly they're operating in a screwed up fashion. I'm really not sure what you're saying there.
C Renner's Auto Electronix
Date Posted: October 05, 2008 at 9:35 AM
they wont lock or unlock with the door switches much less the remote.however they will work for the first millisecond of a new powersource connection.i.e........when you reconnect the battery or replace the fuse in the lock circuit.oh ya the also work when you put the car in gear
guccicrew100
Date Posted: October 05, 2008 at 2:42 PM
There's clearly a short in the doorlock switch circuit. I would suspect it might have something to do with the radio wires being exposed(it's very possible that the same constant power wire goes to both the lock switches and the radio).
Date Posted: October 05, 2008 at 9:54 PM
my thoughts also.especially after seeing all the orange.butwith the pcm being able i thought may be not
guccicrew100
Date Posted: October 06, 2008 at 8:03 PM
Are you saying that shifting into/out of Park unlocks and locks all doors? Or just the driver's door?
If all doors, the problem is almost certainly power to the switches and keyless entry module (I believe it might be separate from the body control module on that truck).
If only the driver's door it could be several things including power to the doorlock relays. The driver's door unlock is controlled separately by the BCM.
