2006 chevrolet aveo, compustar
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=108009
Printed Date: May 11, 2026 at 1:47 PM
Topic: 2006 chevrolet aveo, compustar
Posted By: clint cart
Subject: 2006 chevrolet aveo, compustar
Date Posted: October 08, 2008 at 3:57 PM
Hi, I'm installing one of these in my 2006 Aveo in the next week or so and I can't seen to find any reviews on this starter: https://www.compustar.com/main.htm
I bought it off Ebay (I know, I know...).
So have any of you folks installed one and if so are they any good?, I also bought a: https://ifar.ca/en/products/flashlink_series/key-override-all/
Incase I need it, some say I have one others say I do, hope it works out aswell.
So I guess any input into these products would be great.
Thanks.
Clint.
Date Posted: October 08, 2008 at 4:24 PM
WWW.https://www.compustar.com/main.htm
WWW.https://ifar.ca/en/products/flashlink_series/key-override-all/
Hope that works for the links...
Date Posted: October 09, 2008 at 10:09 AM
Hmmm... I think I'm in trouble.
Posted By: StealthEs
Date Posted: October 09, 2008 at 12:22 PM
It's an OK unit, very basic, about 500 ft range. the control is a single one button type, easy to get into valet mode on that remote and not noticed till you go to use it and you think it doesn't work. Overall great unit for the price which is dirt cheap.
------------- Cris
Posted By: dswift
Date Posted: October 10, 2008 at 6:40 PM
Well keep in mind since its an entry level piece. Compustar has the modular design that allows you to buy the new RF kit for an upgrade. THought you would like to know that.
------------- "dont ground out!"
Date Posted: October 12, 2008 at 7:58 AM
Good to know thanks. I hope it goes well, first time installing a remote start so questions may follow.
Date Posted: November 04, 2008 at 10:22 PM
I hooked mine up to the white wire at the coil, I think it's wrong, I haven't had time to run out and buy a volt meter (Daddy daycare). I have a Compustar CM4200 VD brain. When I press the button on the side for it to learn tach it does nothing, I looked at the grey plug on the firewall for the white wire but theres 4 (I think) if someone is able to pin point this for me you would be forever in my debt. Thanks in advance. Clint.
Posted By: i am an idiot
Date Posted: November 04, 2008 at 10:46 PM
According to the Audiovox Tech website, they say to use any injector wire. generally there will be 2 wires for each injector. There will be one color that appears on every injector. Do not use the common color wire. Use the other wire on one of the injectors.
Date Posted: November 07, 2008 at 4:17 PM
So I checked my tach wire and it reads 1 volt at idle and increases as the RPM's increase. I press the tach learning button on the side and still nothing happens, on relay click, nothing telling me what could be wrong. I cycle the key 5 times and valet mode activates (or deactivates) 2 clicks for the relays and cycle it again and I hear 1 click, then two seconds after 2 more clicks of the relays says my keys in the ignition, I do it again and take the key out altoghether and it does the same thing...
I'm loosing my mind!, I need any help I can get.
it's a Compustar CM4200 VD brain.
Date Posted: November 09, 2008 at 9:56 PM
Changed the tach wire to the white wire in the grey plug on the fire wall inside the car (drivers side). I't a much stronder tach signal but still nothing. It's not in valet mode and it won't go into ready mode to start with the remote. Any idea's?.
