open and close sunroof?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=10854
Printed Date: April 20, 2026 at 6:26 AM
Topic: open and close sunroof?
Posted By: LudeBoi
Subject: open and close sunroof?
Date Posted: March 13, 2003 at 6:50 PM
how would i make my sunroof open and close with 1 power window module? is it possible? i have the viper 550 and a generic window module..thanks in advance
Posted By: Velocity Motors
Date Posted: March 13, 2003 at 6:58 PM
You will only be able to make the sunroof open OR close but not both with only one PWCM.
------------- Jeff
Posted By: LudeBoi
Date Posted: March 13, 2003 at 7:36 PM
ok,i'll guess i'll settle with only close, so i connect the output from the alarm to a relay and the acivation from the PWCM to the relay? how would i connect the rest to the relay? thanks
Date Posted: March 14, 2003 at 5:07 AM
The PWCM doesn't require a relay between the alarm and the module. You should have a ground, constant power, an activation wire, an accessory wire and 4 other wires for the windows. Attach the trigger from the alarm to the activation wire and the rest is self explanatory. You do not need to hook up the ACCESSORY wire to anything.
------------- Jeff
