pin switch
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=10856
Printed Date: April 20, 2026 at 4:41 AM
Topic: pin switch
Posted By: tee17
Subject: pin switch
Date Posted: March 13, 2003 at 7:03 PM
can someone tell me how to install a pin switch in my trunk. i have a hornet 553t alarm on a 92 delta 88. any help is appreciated
Posted By: draasch
Date Posted: March 13, 2003 at 9:26 PM
is there a light that turns on when the lid is lifted?? if tap that wire. if not you may need a bracket to hold the switch. make sure it lines up as not to break the switch when you close the lid. you have to lay inside the trunk with a flashlight to see where the best place would be to mount it. MAKE SURE SOMEONE IS OUTSIDE OF THE TRUNK TO OPEN IT WHEN YOU ARE DONE! lol
you should have a neg. trigger wire on your alarm. run it to the switch adjust the height of the pin switch and your done.
good luck,
david
Posted By: Two_Cold
Date Posted: March 13, 2003 at 10:13 PM
Visit your local Radio Shack and look for a mercury switch. They are small and you can just screw it to the trunk lid. They seem to be getting harder to find though. Maybe check out local electronics shops.
Posted By: tee17
Date Posted: March 14, 2003 at 7:44 AM
Draasch, yes a light does come on. so would i still need the switch or just tap into the wire with the negative trigger.  if so can i use the output from the trunk release.
two cold, thanks i will definitely look into it because i know the last car i had the place that did the alarm used a mercury switch
Posted By: draasch
Date Posted: March 14, 2003 at 7:51 PM
no you can not use the trunk release wire that would be an output. you need a trigger wire. i think you will need a neg trigger wire. im not sure what color it is on your alarm. i dont use that brand. look on the unit it self it might tell you. once you know, use a meter to double check your wire. then you can hook it up.
good luck,
david
