2009 chevy colbalt, remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=108673
Printed Date: May 11, 2026 at 12:50 PM
Topic: 2009 chevy colbalt, remote start
Posted By: tito1829
Subject: 2009 chevy colbalt, remote start
Date Posted: November 04, 2008 at 5:26 PM
does any one have access or have the wire code for a 2009 colbalt im doing alarm and remotestart.thank you
Posted By: caraudio904
Date Posted: November 12, 2008 at 9:48 AM
| MODEL | YEAR(S) | | COBALT | 2006 -2008 |
| KEY | T-HARNESS | IMMOBILIZER | | N/A | N/A | GM'S PASSKEY 3 TRANSPONDER ANTI-THEFT SYSTEM, Requires BYPASS PKUGM2X OR XK06 |
| PART | COLOR | LOCATION | | 12 VOLT CONSTANT | RED / BLACK (+) | @ BCM, C3, Pin D1, See NOTE *1 | | STARTER | YELLOW (NOT Required for REMOTE START) See NOTE *2 | @ PCM, BLUE Plug, Pin 48, 46 or 56, See NOTE *2 | | STARTER 2 | N/A | | | IGNITION 1 | YELLOW (+) | @ IGNITION HARNESS or BCM, C4, Pin D3, See NOTE *1 | | IGNITION 2 | N/A | | | IGNITION 3 | N/A | | | ACCESSORY /HEATER BLOWER 1 | N/A | @ IGNITION HARNESS or BCM, C4, Pin C8, See NOTE *1 | | ACCESSORY /HEATER BLOWER 2 | N/A | | | KEYSENSE | N/A | | | PARKING LIGHTS ( - ) | BROWN / WHITE (-) | @ HEADLIGHT SWITCH or BCM, C2, Pin 5, See NOTE *1 | | PARKING LIGHTS ( + ) | BROWN (+) | IN DRIVERS KICK PANEL or BCM, C2, Pin 5, See NOTE *1 | | POWER LOCK | WHITE (1-Wire Door Lock System) See NOTE *3 | IN DRIVERS KICK PANEL or BCM, C1, Pin 7, See NOTE *1 | | POWER UNLOCK | Same wire | See DIAGRAMS | | DOOR TRIGGER | See NOTE *4 | IN EACH KICK PANEL or BCM, C1, See NOTE *1 | | DOMELIGHT SUPERVISION | GRAY (-) | @ BCM, C3, Pin A10, See NOTE *1 | | TRUNK RELEASE | TAN (-) | @ TRUNK RELEASE SWITCH or BCM, C2, Pin 10, See NOTE *1 | | SLIDING POWER DOOR | N/A | | | HORN | TAN (-) | @ HORN SWITCH or BCM, C2, Pin 14, See NOTE *1 | | TACH | ANY wire NOT PINK or PINK/BLACK | @ ANY FUEL-INJECTOR | | WAIT TO START LIGHT | N/A | | | BRAKE | LIGHT BLUE (+) | @ SWITCH ABOVE BRAKE PEDAL | | FACTORY ALARM DISARM | DISARMS with FACTORY REWMOTE ONLY!! | | | ANTI-THEFT | GM'S PASSLOCK 3 TRANSPONDER ANTI-THEFT SYSTEM | @ IGNITION TUMBLER |
| EXTRA INFORMATION | | NOTE *1 the BCM is part of the FUSE/RELAY BOX on the front PASSENGER SIDE of the CENTER CONSOLE. The BCM has the following connectors: C1-72 Pin GRAY Plug, C2-72 Pin GRAY Plug, C3-41 Pin RED Plug, and C4-68 Pin LIGHT GRAY Plug, the C4 Plug, is located on the BACK of the BCM. NOTE *2 the PCM (Powertrain Control Module) is located on the DRIVERS SIDE FENDER, in FRONT of the UNDER HOOD FUSE BOX. The YELLOW STARTER wire is NOT required for REMOTE STARTING. THIS VEHICLE REQUIRES A PKUGM2X OR XKO6 WITH PKG7 2.0 FIRMWARE BYPASS FOR REMOTE STARTING. NOTE *3 This vehicle uses a 1-Wire Door Locking System that will require extra parts. The LOCK requires a Straight (-) Negative and the UNLOCK requires a (-) Negative thru a 1500 Ohm Resistor. Some units will also require (2) extra Relays Part #775 for this function, to connect See DIAGRAMS. NOTE *4 The DRIVERS DOOR is a GRAY/BLACK (-) Pin 22, The PASSENGERS DOOR is a TAN/WHITE (-) Pin 19, The DRIVERS REAR DOOR is a LIGHT BLUE/BLACK (-) Pin 1 and The PASSENGER REAR DOOR is a LIGHT GREEN/ BLACK (-) Pin 20, when connecting to an ALARM SYSTEM use all 4 wires and DIODE ISOLATE, to connect See DIAGRAM |
------------- Southern Stylez
Jacksonville, FL 32218
