03 dodge ram, alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=108692
Printed Date: May 11, 2026 at 2:40 PM
Topic: 03 dodge ram, alarm
Posted By: deames
Subject: 03 dodge ram, alarm
Date Posted: November 05, 2008 at 3:45 PM
I have an 03 Dodge ran that has factory keyless entry. It also has a panic button on the remote that flashes the lights and blows the horn. My question is, can I tie my alarm into this module to save me some wiring ? I want the alarm to set off the panic function when triggered, and to lock and unlock the doors.
Posted By: mikvot
Date Posted: November 05, 2008 at 3:56 PM
Nope, you will have to start from scratch.
Posted By: deames
Date Posted: November 05, 2008 at 4:00 PM
Thanks. Should I remove the keyless entry or just leave it attached ?
Posted By: ckeeler
Date Posted: November 05, 2008 at 4:01 PM
an aftermarket alarm system will lock and unlock the doors so no worry there, but to try to install one the way you want is much more work than if you just install the alarm. it will actually do the opposite of save you time.
Posted By: ckeeler
Date Posted: November 05, 2008 at 4:10 PM
just leave in the factory keyless unit. dont do anything with it.
Posted By: deames
Date Posted: November 05, 2008 at 8:28 PM
OK Thanks for all the replies.
