viper 5501 guide
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=108706
Printed Date: May 08, 2026 at 4:01 AM
Topic: viper 5501 guide
Posted By: jasonlipka
Subject: viper 5501 guide
Date Posted: November 06, 2008 at 8:23 AM
Hey guys, just wondering if anyone on here had access to the Directeddealers.com site and could get me the installation guide for the brand new Viper 5501 remote starter?  I realize the install guide may not be out yet.  If that is the case, could you get me the install guide for Viper 5301 remote starter.  I imagine they are pretty similar installations.
Thanks!
Posted By: flybyu
Date Posted: February 17, 2009 at 8:47 AM
to the top. i'd like one also
Posted By: loneranger
Date Posted: February 17, 2009 at 2:57 PM
This should provide you with the information you need.
https://www.the12volt.com/installbay/file.asp?ID=710
Ideal - cmon dude, add to topics in a useful manner, not stuff that is obvious.
Story - Phzzzt! Hey, what happened?! ... Isn't it obvious?
Moral - Never dismiss the obvious.
Posted By: flybyu
Date Posted: February 17, 2009 at 3:14 PM
thats the 5701. which is security and remote. but it should be close. thanks
Date Posted: February 17, 2009 at 3:21 PM
As I said, it should provide you with the information you need. It's more than close. Regarding the R/S portion, it's exact.
Posted By: tfrain
Date Posted: February 25, 2009 at 10:21 AM
I just had the responder one installed by a dealer and I think they don't know what they are talking about.  Does anyone have the guide for the 4203V - responder one - what I need is the programming  info which woudl be different since there is no alarm to chirp and only 1 button.
The guy said it didn't do ignition on/off and clearly it does.  Also the dome light stays on until I open/close the door after disengaging the remote start via the ignition key to on - Viper said they need to get a pulse from the door or something (I called them yesterday).
Additionally, they just coiled the antenna wire up under the dash which the manual EXPLICITELY states not to do, so I think that is affecting my range.
On that note - what kind of range can I really expect?  Viper said 500 to 1000 feet regardless of interference.  Is it unrealistic to expect to be able to start the vehicle from inside the target or grocery store?  That is not two football fields away by any stretch.
If it won't start it from inside a store, then would the 5501 or 6901 which supposedly have 1 mile range be able to do it?  If so, would it be easy for the dealer to swap modules?  (IE are the harnesses the same?).
Sorry for all the questions - I should have installed the thing myself but figured I'd get a pro to do it to save myself the 2 days of getting through it all - but alas....
Thanks for any replies!!!
Posted By: smokeman1
Date Posted: September 18, 2009 at 8:47 PM
Hi all,
Has anyone got a Installer Guide for a Viper 5301 Remote Starter they can upload or copy for mailing???
I had on installed by B--- Buy but they did not give me the installer guide. I was wanting it for the menus and how to program additional remotes.
