2009 corolla, lighted door sill trim
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=108725
Printed Date: May 07, 2026 at 9:26 PM
Topic: 2009 corolla, lighted door sill trim
Posted By: russbm
Subject: 2009 corolla, lighted door sill trim
Date Posted: November 06, 2008 at 10:21 PM
Has anyone install a lighted door sill trim on a 2009 Corolla, trying to find the correct wire to light it up when the door is open.
Posted By: i am an idiot
Date Posted: November 06, 2008 at 11:03 PM
     LF Latch          VIOLET          (-)          AT MAIN BODY ECU
     RF Latch          TAN          (-)          AT MAIN BODY ECU
     LR Latch          YELLOW          (-)          AT MAIN BODY ECU
     RR Latch          BLACK          (-)          AT MAIN BODY ECU
Posted By: Chris Luongo
Date Posted: November 07, 2008 at 6:50 AM
Or you could just use the domelight wire if you want:
To the left of the steering column, there's a panel with three switches, and the coin pocket below it.
If you open the pocket and put your fingers inside, that whole panel should just pop right off. (I really can't remember if you have to unscrew and remove the panel under the steering wheel first or not. Pull slowly and carefully to make sure one panel doesn't overlap the other.)
Right behind there is the fuse box/body computer.
On the lower left, you should pretty easily see a plug with a few wires coming out, and they all go right up the A-pillar to the driver's ceiling.
I think (but test!) that the lower-left of these wires is the car's negative domelight wire. There should be also constant power, ground, and ignition (for the sunroof) in that same plug.
Your doorsill lights are probably LEDs, right? I would imaginve that they wouldn't draw much current, and you'd be ok just to add them into the car's domelight circuit like that.
