2008 hyundai accent remote start/alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=108738
Printed Date: May 07, 2026 at 2:50 PM
Topic: 2008 hyundai accent remote start/alarm
Posted By: knate
Subject: 2008 hyundai accent remote start/alarm
Date Posted: November 07, 2008 at 2:16 PM
I need a remote start/alarm wire diagram for a 2008 hyundai accent. If anyone can help or if you know it is the same as the 2006 Accent.
------------- Nathan
Posted By: knate
Date Posted: November 07, 2008 at 2:19 PM
Also, I have had trouble with hyundai putting the '09 wire harness for the stereo in the '08s already. If you know about anything like this with the alarm wiring please let me know. Any help is appretiated.
Posted By: another-kelly
Date Posted: November 07, 2008 at 10:34 PM
2008 HYUNDAI ACCENT 4DR SEDAN
Security
WIRE COLOR POLARITY LOCATION
Battery GREEN & BLUE (+) IGNITION SWITCH HARNESS
Ignition 1 PINK (+) IGNITION SWITCH HARNESS
Starter 1 WHITE (+) IGNITION SWITCH HARNESS
All Door Trigger GREEN (-) IN HARNESS IN DRIVERS KICKPANEL
Domelight Super GREEN (-) AT BCM MODULE TO RIGHT OF STEERING COLUMN
Trunk Trigger GREEN/ ORANGE (-) IN HARNESS IN DRIVERS KICKPANEL
Hood Trigger BROWN (-) AT VEHICLE HOOD PIN SWITCH
ALSO AT BCM MODULE TO RIGHT OF STEERING COLUMN
Alarm Disarm WHITE/ BLACK (-) IN HARNESS IN DRIVER KICKPANEL
Parking Lights RED (-) AT VEHICLE LIGHT SWITCH
Remote Start
Accessory 1 ORANGE (+) IGNITION SWITCH HARNESS
Accessory 2 YELLOW (+) IGNITION SWITCH HARNESS
Key Sense BLUE (+) IGNITION SWITCH HARNESS
Tachometer GREEN (AC) AT ECM/PCM MODULE BETWEEN DRIVER SIDE FIREWALL AND AIR CLEANER ASSEMBLY
Speed Sense RED / ORANGE (AC) AT DATALINK CONNECTOR UNDER DRIVER DASH
Brake Lights GREEN (+) AT SWITCH ABOVE BRAKE PEDAL
MAY ALSO BE ORANGE
Reverse Lights WHITE/ BLACK (+) IN HARNESS IN DRIVER KICKPANEL TO REAR
Horn BLUE (-) IN HARNESS AT STEERING COLUMN
Doorlocks/Windows
Power Unlock YELLOW/BLACK (-) IN HARNESS IN DRIVER KICKPANEL
PowerLock BLUE (-) IN HARNESS IN DRIVER KICKPANEL
Driver Mtr Unlock PINK (REV) IN HARNESS IN DRIVER KICKPANEL
Driver Mtr Lock BLUE (REV) IN HARNESS IN DRIVER KICKPANEL
LF Window Up GREEN (REV) DRIVER WINDOW CONTROL SWITCH
LF Window Dn ORANGE (REV) DRIVER WINDOW CONTROL SWITCH
RF Window Up BROWN (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR
RF Window Dn GRAY (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR
LR Window Up YELLOW (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR
LR Window Dn WHITE (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR
RR Window Up GREEN (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR
RR Window Dn BLUE (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR
Posted By: knate
Date Posted: November 08, 2008 at 1:42 AM
Doesn't matter for three or four door right? I have the three door, hatchback.
Date Posted: November 08, 2008 at 10:46 AM
2008 HYUNDAI ACCENT 2DR HATCHBACK
Security
Remote Start
MAY ALSO BE ORANGE
Modules
Doorlocks/Windows
