1990 honda accord, alarm wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=108739
Printed Date: May 07, 2026 at 1:48 PM
Topic: 1990 honda accord, alarm wiring
Posted By: peleno1
Subject: 1990 honda accord, alarm wiring
Date Posted: November 07, 2008 at 2:22 PM
Hi Guys/Girls Have started to install a car alarm in my car but have run in to trubble finding some cables in the harness in the car... "Hope all can read my swinglish ;-) Live in sweden if all wonde why i spell like a monkeyr" Looking for the Power Door Lock (-) Black / White 2 pin harness in driver`s kick, wrapped in blue tape and also Power door unlock (-) Black / Red 2 pin harness in driver`s kick, wrapped in blue tape... Have looking for this cables for several hour but can`t find them :-( Am i starting to get colour blind?..... *Lol*
Also i need some more pro help from you here on this forum.... I`m not realy sure how to connect the starter Relay to the ignition harness on my car, would be happy if some can write up how to connect this relay on my car...
Posting some pictures so all can see the fuse box on the car and also the diffrent harness in the kick panel on my car...
Posted By: ckeeler
Date Posted: November 07, 2008 at 2:27 PM
i love doing these cars! piece of cake! the door lock wires are going to be up high in the driver side, they will be in a 2 pin white connector and be the only 2 wires in it. sometimes they are tapped to a larger harness with......you guessed it......blue tape. just look a little higher up in there.
Posted By: peleno1
Date Posted: November 07, 2008 at 2:31 PM
Good i have get a answer from a PRO :-) You know i have looked alot but still i can`t find the wires :-( And also i`m not realy sure how to connect the starter relay, so i would be werry happy if you can tell me how to connect this to the starter harness....
Best Regards to you...
Posted By: peleno1
Date Posted: November 07, 2008 at 2:34 PM
I have bought this Alarm is it good or only crap? https://www.lff.cn/EN/product.asp?id=169
Posted By: ckeeler
Date Posted: November 07, 2008 at 2:42 PM
seems ok, im sure its goon work fine. the first thing is finding the lock wires and then wiring the starter kill relay.
Posted By: KarTuneMan
Date Posted: November 07, 2008 at 8:39 PM
Look lower for your locks. grab in a harness in the running board area. Locks, brake light, and parking lights are there too! -------------
Posted By: OmarR
Date Posted: November 07, 2008 at 8:56 PM
Definitely lower for the locks. That 2 pin harness should be hanging around your fuse block (bottom of your pic).
Posted By: OmarR
Date Posted: November 07, 2008 at 9:22 PM
As for the the starter kill relay, using your diagram: Cut the BLACK/ white starter wire Key side of BLACK/ white wire - 86 & 87a Starter side of BLACK/ white wire - 30 Yellow (-) from alarm - 85 87 is not used. If you are not sure as to which side is which on the BLACK/ white wire AFTER you cut it, turn and hold the key towards the start position. The side getting 12V is the key side.
Posted By: peleno1
Date Posted: November 08, 2008 at 3:45 AM
Thanks all for answering to my trubble.. Sorry to say all install PDF files and som on don`t make me to find the right cables for this Power Lock and Unlock :-(
I have ripped apart the whole electrical system in the car but can`t find the 2 pin connector all talking about..
I post pictures and see what you say where the cables normally will be in the car...
Posted By: peleno1
Date Posted: November 08, 2008 at 4:01 AM
In the 12volt install it written: Under carpet below Fuse 2 pin connector
In the Directwire install its written: lower drivers kick
In CarAlarmPros install is written: 2-pins harness in drivers kick, wrapped in blue tape even if i did have all this install manuals i can`t find the cable for this lock and unlock....I have found a cable wrapped with blue tape but there is only one cable and its yellow.....
Looks like an need to skip this power lock thing in my car :-(
Posted By: OmarR
Date Posted: November 09, 2008 at 1:04 AM
The first 12V description sounds like the most accurate. It's been a while since I had my 1991 Honda Accord, but if I remember correctly, I did have to pull the carpet back to reveal the 2 pin harness. https://home.san.rr.com/tahoe/fuseboxfs5.jpg
Posted By: peleno1
Date Posted: November 09, 2008 at 2:32 PM
Have looked down under the carpet but nothing... I belive that the did have a hell of a party in the honda manufacturing when assambled my car hehe. They did forget to complement my electrical system in my car with a 2 pin harness....
Did ripped down the electrical system again today and did not find the cable for the lock....
But i can be without it, allmost all other in the alarm is working but not the starter kill relay, have connected it as it should be but if the alarm goes off i still can start the engine. Have tryed to shift the cables 86 and 87a to 30 and the other way, Still the car is starting with out no problem...
