Commando 550-s
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=10877
Printed Date: April 19, 2026 at 9:45 PM
Topic: Commando 550-s
Posted By: Richard2
Subject: Commando 550-s
Date Posted: March 14, 2003 at 10:02 AM
The system is working great and easy to install,,,but can't figure out what the small button on the side of the transmitter is for? It is called a five button transmitter, but fifth button doesn't seem to do anything...that I can figure out. If anyone knows please let me know....Thanks....I think this is a great site.
Commando 550-S.
Posted By: badtoad
Date Posted: April 03, 2003 at 8:12 PM
I'm not sure about your model, however on my clifford it is a shift button. press once for channels 5,6,7,8 or twice for 9,10,11,12
Mike
Posted By: draasch
Date Posted: April 03, 2003 at 10:50 PM
how many speeds is that??
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: shawn240sx
Date Posted: April 06, 2003 at 7:26 AM
I just bought the 550-s alarm and was wondering if you hooked up the keyless entry option?  And if so did u put a fuse on the 12v to the relays??? I am gtting an unusally hot wire...i am not sure if this is because of wire guage or requiring an inline fuse??
Thanx
Posted By: jrilla
Date Posted: April 06, 2003 at 7:11 PM
The button on the side is for controlling another vehicle if you had two 550s alarms. like one in your wifes car and one in your own, you could use just one transmitter to control both cars. Or I had a customer want his main transmitter programmed so that he had to press the button on the side before pushing any buttons because he kept starting his car accidently when his keys were in his pocket. Cripe this guy had about 40 keys on his key chain.
J Rilla
Owner/Installer
Date Posted: April 07, 2003 at 2:20 AM
Anyone know about the 550-s wring for adding actuators???  I am having problems with wire heat up?...I am using 16guage....should i use a 12awg and inline fuse??  First time installing alarm with keyless entry...can anyone help??
thanx
240sx 92
Posted By: jrilla
Date Posted: April 07, 2003 at 10:22 AM
Shawn you should start your own thread.
How do you have your relays wired for the actuators?
J Rilla
Owner/Installer
Date Posted: April 07, 2003 at 3:30 PM
I have them wired as directed in the manual. However I have heard that i should not use the ones sold at car stores since they are not spdt???  Is there anywhere else we can get them locally?
Shawn240sx
Posted By: Richard2
Date Posted: April 10, 2003 at 9:20 AM
Shawn my Grand prix had stock elect. door locks, I used two relays wired with 12 gauge wire to operate them and the power line is fused from the car fuse panel. I am also using the two step unlock (one click for driver's door and two click for all doors). Haven't had any trouble with the system. Good luck.
