08 corvette ignition switch pinout
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=108780
Printed Date: May 07, 2026 at 12:34 AM
Topic: 08 corvette ignition switch pinout
Posted By: tqmnster
Subject: 08 corvette ignition switch pinout
Date Posted: November 09, 2008 at 2:23 PM
I bought an ignition switch from a 08 corvette and I need the pinout for the switch. It has a 10-pin plug on the back. Just need to know what each pin is for. Thanks.
Posted By: i am an idiot
Date Posted: November 10, 2008 at 9:43 PM
What are you trying to do with the switch? Are any of the connections of substantial size? Do you have the key?   If you have an ohm meter and some time to do some footwork, I can probably help you figure out enough of the switch to be able to use it.
Posted By: tqmnster
Date Posted: November 11, 2008 at 7:29 AM
I'm using it for a keyless ignition setup I'm putting together. I tried using an ohm meter and figured out a little bit but not much. Its a 10 pin connector like this....
1     2      3     4     5
6     7     8     9     10
I've figured out that.....
- 7 & 8 are connected permanently. So I'm guessing the led light is poweRED / grounded by these
- 5 & 10 are connected when the Start side is pushed in.
- 1 & 6 are connected when the Off/ACC Side is pushed in. It is also actived when the Start side is pushed as well but it read alot more ohms than it does when the Off side is pressed
- 2,3,4,9 I can not get to read anything.....
Date Posted: November 11, 2008 at 9:29 PM
Does the off/acc side of the switch stay down when you press it?
Posted By: tqmnster
Date Posted: November 12, 2008 at 7:17 AM
No its just a momentary pulse type switch I guess thats how you'd describe it.
Posted By: KPierson
Date Posted: November 12, 2008 at 8:05 AM
Do you have any pictures of the switch?
Kevin Pierson
Posted By: tqmnster
Date Posted: November 12, 2008 at 8:08 AM
Just one of the front of it.
posted_image
The back of is laid out like I put the numbers, with the number representing the pins.
Posted By: KPierson
Date Posted: November 12, 2008 at 8:14 AM
How many lights does the switch have?  Can you take it apart?
Kevin Pierson
Posted By: tqmnster
Date Posted: November 12, 2008 at 8:28 AM
I'm guessing 3 at the most. I was hoping someone would/could come up with a pinout/wiring diagram for this thing so I wouldnt have to take it apart but it looks like I will be taking it apart now. I THINK it has three lights. One for the start portion and two for the off and ACC.
Posted By: KPierson
Date Posted: November 12, 2008 at 10:37 AM
so three LEDs and two switches?
I would guess that the LEDs have a common + and individual - triggers.
I would also guess that the switch sides switch a - signal.  I'm not sure what the other pins would be for.  Is there continuity between any of the other pins besides the two you already identified?
Kevin Pierson
Posted By: tqmnster
Date Posted: November 12, 2008 at 10:51 AM
Yeah I think the ones I havent identified maybe be leds that are switched closed when the lights are on like a relay so thats why they arent showing thet theyre connected at the moment. Also the only one I know are connected are the ones stated.
Posted By: silent bob
Date Posted: November 12, 2008 at 1:48 PM
here you go:
A
0.35 L-BU/WH
5725
Ignition Mode Switch Mode Voltage Backup
B
0.35 D-BU
5719
Ignition Mode Switch Start LED Signal
C
0.35 BN/WH
230
Instrument Panel Lamp Dimming Control
D
0.35 BK
1450
Ground
E
0.35 L-GN/WH
5723
F
0.35 L-GN
5724
Ignition Mode Switch Mode Control
G
0.35 PK
5722
Ignition Mode Switch LED Supply Voltage
H
0.35 OG
5721
Ignition Mode Switch Off LED Signal
J
0.35 L-GN
5720
Ignition Mode Switch Accessory LED Signal
K
0.35 L-BU
5726
Ignition Mode Switch Mode Control Backup
the part came out once
therefore it must go back in
where is that hammer
