2004 silverado 2500hd diesel, remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=108874
Printed Date: May 07, 2026 at 12:07 AM
Topic: 2004 silverado 2500hd diesel, remote start
Posted By: rhelton075
Subject: 2004 silverado 2500hd diesel, remote start
Date Posted: November 12, 2008 at 7:35 PM
I tried searching the site for a wiring diagram for my truck but have had no luck. All I can find is 1500 models. I want to install a Ready Remote model 24927 on my 2004 Chevy Silverado 2500HD diesel ext. cab. If any one has diagrams they could post it would be a big help. Thanks.
Posted By: i am an idiot
Date Posted: November 12, 2008 at 8:15 PM
I can only assume that a ReadyRemote 24927 is a remote start unit,  If so the following should help.
posted_imageBatteryRED(+)IGNITION SWITCH HARNESS
posted_imageIgnition 1PINK(+)IGNITION SWITCH HARNESS
posted_imageIgnition 2WHITE(+)IGNITION SWITCH HARNESS
posted_imageAccessory 1ORANGE(+)IGNITION SWITCH HARNESS
posted_imageAccessory 2BROWN(+)IGNITION SWITCH HARNESS
posted_imageStarter 1YELLOW(+)IGNITION SWITCH HARNESS
posted_imageAnti-Theft TypePASSLOCK II
posted_imageAnti-Theft DescriptA RESISTANCE BASED SYSTEM
posted_imageKey SenseLIGHT GREEN(-)AT STEERING COLUMN HARNESS
posted_imageTachometerWHITE(-)AT INSTRUMENT CLUSTER
posted_imageGlow PlugDK.BLUE(-)BEHIND THE INSTRUMENT CLUSTER
posted_imageCamshaft SensorPINK/BLACK
posted_imageSpeed SenseGREEN / WHITE(AC)IN HARNESS ON DRIVERS SIDE OF ENGINE COMPARTMENT
posted_imageParking LightsVIOLET(-)AT VEHICLE LIGHT SWITCH
posted_imageLow Crr. Pk LightsGRAY/BLACK(-)AT LIGHT SWITCH OR BROWN PLUG AT BCM PIN B2
posted_imageBrake LightsWHITE(+)AT BRAKE PEDAL SWITCH
posted_imageReverse LightsLIGHT GREEN(+)BCM BLACK PLUG PIN F
posted_imageHornBLACK OR BLACK / YELLOW(-)AT STEERING COLUMN HARNESS
Date Posted: November 13, 2008 at 12:03 AM
Thank you for the information. Yes it is a remote start unit but it also has keyless entry and alarm. Also i was looking through some posts and saw some people saying that when they hook up there wait to start or glow plug wire to the remote start unit it will throw a code causing your check engine light to come on. Has anyone had any experience with this.
Date Posted: November 13, 2008 at 6:10 AM
Is the unit programmable for a diesel?   If so you can usually set it to diesel and some have choices of times to delay the start.  10 20 or 30 seconds.  Depending on how far North you are, you choose the appropriate time.    I will get you door lock and alarm info this evening.
Date Posted: November 14, 2008 at 7:07 AM
Yes it is programable, I will use that over hooking it up to the glow plug wire.
Date Posted: December 09, 2008 at 12:23 AM
 just installed a readyremote remote start w/keyless entry and alarm on my 2004 Chevy Silverado 2500 HD Diesel. The keyless entry and alarm features work but the remote start is not.  When I press the button on the fob the truck flashes its lights, honks its horn, and the accessories flash on and off in the cab like it is going to start but then nothing happens.  If this has happened to anyone else what are some things I could look for.  All my connections are soldered my fuses are good.  When I check the voltage on my starter “yellow” wire I am not reading anything during the remote start. I also checked my brake and hood switch. Any ideas would help.
Posted By: KarTuneMan
Date Posted: December 09, 2008 at 8:16 AM
So the yellow wire.... is this the output from the unit?
what bypass did you use?
Date Posted: December 09, 2008 at 4:11 PM
Yes the yellow wire is the 12 volt output to the starter. And i am using the directed 1700G combo unit.
Date Posted: December 09, 2008 at 4:58 PM
Thanks for the help guys i got it working. I called DEI tech support  and they had me open the unit on the ready remote 24927 and remove the R20 resistor. When i hooked it back up it started right up.
