2007 corola remote starter
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=108907
Printed Date: May 07, 2026 at 12:32 PM
Topic: 2007 corola remote starter
Posted By: tktom64
Subject: 2007 corola remote starter
Date Posted: November 14, 2008 at 6:24 AM
Helo friends, I 'm need some help please: I'm installing remote start on 2007 Corola and have few technical problem as below:
_Door lockunlock = GREEN/ BlueYellow per wiring diagram indicated but when i test with test ligth no reading (negative pulse)
_Can not find parking light Green per diagram driver kick, harness to rear.
_Per diagram this vehicle not equiped with Immobilizer system, but when I test it won't start unless key are in ignition cylinder ( Do I need bypass module?).
_Should I connect status wire from remote start to keysense wire to disarm while remote start?
Thanks in advance
Tom
Posted By: Big Dog
Date Posted: November 14, 2008 at 11:21 AM
The doorlock/unlock green and blue / YELLOW are the ones close to the driver footrest in a white 10 pin plug. With door latched, sending a ground pulse on the green will lock. A ground pulse to the blue / YELLOW will unlock the drivers door....a second pulse will unlock the other doors.
The green parklight wire is in the harness running to the rear near the drivers seat - I believe it's the only green.
This car has an immobilizer. If you go to this sites "Application Guides" you'll have several options for bypass modules.
To disarm (if required) : I can't remember if keysense disarms or not on this car. An option would be to use the "Factory Alarm Disarm" wire of the remote starter to send a ground pulse to the same blue / YELLOW as the unlock wire. You'll also have to send a pulse to the lock wire after the car starts to re-lock the doors.
Prepare your future. It wasn't the lack of stones that killed the stone age.
Posted By: tktom64
Date Posted: November 14, 2008 at 11:53 AM
Thanks for your quick help Big, I will try your advised.
Again thanks all of the help from this site
Tom
Posted By: Mike M2
Date Posted: November 14, 2008 at 3:40 PM
The lock wires will not test with the switch on the door, you need to turn the key in the lock for the readings.
No Corolla on this planet has a factory alarm, so keysense is not needed. The security light pertains to the immobilizer only.
BigDog is right, the harness to the rear for park light. You can also go to the back of the dashlight switch located above the pocket if you wish, still a green wire...
Mike M2
Tech Manager
CS Dealer Services
