Multiple Sirens
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=109
Printed Date: May 13, 2026 at 5:57 AM
Topic: Multiple Sirens
Posted By: ogb1
Subject: Multiple Sirens
Date Posted: March 21, 2002 at 10:29 AM
I have my regular siren, and a battery backed up siren currently hooked up....  i want to add a couple piezo sirens to the interior but i was told my alarm couldnt handle more then 2 sirens.  How do i put a relay in so i can add more sirens?  and do i wire the sirens up in parrallel with the sirens i have now?
Posted By: the12volt
Date Posted: March 21, 2002 at 1:48 PM
Hi ogb1, connect a lead to your alarm's siren output. if your alarm's siren output is (+) connect it to termianl #85 and connect #86 to ground. If the output is (-) connect it to terminal #85 and connect #86 to a constant 12V+ (fused).
Connect terminal #87 to constant 12V+ (fused) and connect terminal #30 to the positive leads of the other sirens you are adding. Connect their negative leads to ground. Leave all other siren connections as there are.
the12volt
Posted By: hot_shot_guy123
Date Posted: March 21, 2002 at 1:50 PM
Hi there, I was on here before and I had the same question.  I have 2 external battery back-up sirens, three mini piezo sirens inside and a seperate battery just for my alarm.  People helped me so I figure I might as well help too.  The relay is easy to hook up to your alarm.  First of all you have to know if your alarm has a positive or negative trigger.
RELAY
PIN 86 = trigger wire from siren output from brain (pos or neg depending on your alarm)
PIN 85 = Ground
PIN 87 = Constant 12V  (make sure to fuse this wire)
PIN 30 = Hook up sirens to this pin
