problem autopage rs1000
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=109141
Printed Date: May 11, 2026 at 4:27 AM
Topic: problem autopage rs1000
Posted By: skostur79
Subject: problem autopage rs1000
Date Posted: November 22, 2008 at 11:40 AM
can anyone with autopage experience help me out , i just installed a rs1000 2 way , tested , learn rpms all good all functions work, the next day i got nothing from transmitter 1 or 2 , turning the ign , the locks cycle like the should , i dropped the module down checked all connections , powers ,grounds good i can enter programing mode but since it dont pick up the transmitter , it exits, so how can i diagnose a bad transmitter or bad module? i dont think autopage will help me with warrentys thanks
Posted By: p01110101
Date Posted: November 22, 2008 at 12:08 PM
try re-learning the remotes, your manual should tell you how to do it.
Date Posted: November 22, 2008 at 12:16 PM
ya i tryed that i get the step (press any key on the fob ) but no chirp the 15 sec it times out any more suggestions , thanks
Posted By: lamikela1
Date Posted: November 25, 2008 at 4:05 PM
If you tried both remotes and no luck then I would suspect that the antenna or module is bad as both remotes can't be bad. If you know someone who has another RS-1000 try to program your remotes on that system to see if they work. If you can find a shop that installs them they may have a test system that you can try them on.
------------- Pioneer AVIC-Z1, JL 8W3V2, XR650CSi, 300/4, 250/1, Bluetooth, XM, A/V switch, Backup Cam, Autopage RS-1000
Date Posted: November 25, 2008 at 6:51 PM
ya im bummed because i just installed it , the local autopage shop wont look at it unless they installed it, , but they will sell me a new one for 650..00 i called autopage ,they will check it out, but 2 plus weeks to get it there and repaired , i sent it off
Posted By: ceasar326
Date Posted: November 25, 2008 at 9:33 PM
Have u checked the ground point make sure its a good ground ive dealed with autopage alot. Ground points are your best bet.
Date Posted: November 25, 2008 at 9:59 PM
Ya grounded at dash crosscar bar .2 ohms
I can ground the h10/18 wire and it will remote start ok
Thanks I'll post the findings once I get it back
Date Posted: December 30, 2008 at 7:54 PM
well finally after about a month autopage sent the repaired unit, no faults in the remotes , replaced the main control module so far it works maybe i can make into winter with it now ,,,
