07 saturn ion, door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=109203
Printed Date: March 28, 2026 at 8:10 AM
Topic: 07 saturn ion, door locks
Posted By: art lopez
Subject: 07 saturn ion, door locks
Date Posted: November 24, 2008 at 1:27 PM
im trying to the power door lock s to work but it seems that i cant not get it wrigth this is what i did i put my wire to lock direct - and my unkock wire with my resister and it those not work it only work lock cant any body help me with this
dr boom
Posted By: Chris Luongo
Date Posted: November 24, 2008 at 5:49 PM
1. Have you already used the search feature here?
2. What kind of remote starter?
3. Does the remote starter have reversing polarity (+/-) doorlock outputs, or just negative outputs?
Date Posted: November 24, 2008 at 6:16 PM
i try to work on it againg i saw that to open the door lock u need to push the button twice to lock and ones to unlock so i think that i need a alarm that has double lock pulse and the alarm im using does not have double pulse lock so i think that my alarm is the problem
dr boom
Posted By: ckeeler
Date Posted: November 24, 2008 at 6:45 PM
double pulse "LOCK"? are you testing this with the doors open? try closing the doors and then try it.
Date Posted: November 24, 2008 at 7:25 PM
i did try with the door close and same think  it takes to push the button two times two close and one time to open and thats pushing the button in the car
dr boom
Posted By: ckeeler
Date Posted: November 24, 2008 at 7:57 PM
are you using relays? you need to send the negative pulse through relays on this vehicle if your unit does not have them built in.
Posted By: ckeeler
Date Posted: November 24, 2008 at 9:52 PM
got to thinking about this and well........are you pulling my leg?? you mean to tell me that if your sitting inside your car with the keys in your hand and the doors closed you have to push the lock button twice before the doors will lock? dude........cmon, i wasnt born yesterday.
Posted By: big sexy lac
Date Posted: November 24, 2008 at 10:43 PM
You need a relay for unlock
WELL?
