2006 pontiac torrent remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=109248
Printed Date: March 29, 2026 at 7:04 PM
Topic: 2006 pontiac torrent remote start
Posted By: oldsmobile94
Subject: 2006 pontiac torrent remote start
Date Posted: November 25, 2008 at 9:21 PM
ok i want to install a hornet 564t into a 2006 pontiac torrnet an need all the wires. this is all that is listed. https://www.the12volt.com/installbay/forum_posts.asp~TID~80348
as you can see its missing a few wires. an if anyone has the rest i'd appreciate it. thanks
------------- TK
Date Posted: December 20, 2008 at 11:27 PM
just wonderin if any1 has an idea of the other wires
------------- TK
Posted By: jar754
Date Posted: December 21, 2008 at 8:23 PM
12volt constant- (+)red x2
starter- yellow
ignition 1- (+)pink
accessory- (+)orange
keysense - (-)light green
parking lights(-)- (-)light blue
parking lights(+)- (+)brown
power lock- light blue - type a
power unlock- dark blue
door trigger - (-)gray/black driver
(-)tan/white pass
domelight - (-)white
horn- (-)tan
tach- purple
brake- (+) light blue
factory disarm- disarms w/factory
remote only
anti theft- paslock 2
vehicle cranks when accesory wire sees 12 volts,then drops out.vehicle will crank,starter wire not required for remote starting. when connecting to an alarm both door triggers must be diode isolated
Date Posted: December 22, 2008 at 9:00 PM
thanks
------------- TK
