2008 envoy remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=109410
Printed Date: May 10, 2026 at 11:50 AM
Topic: 2008 envoy remote start
Posted By: f7nightfire
Subject: 2008 envoy remote start
Date Posted: December 02, 2008 at 3:43 PM
installed autosrtart  1755  and bmdlbp bypass  and having problem starting   flashes park lights 6 times   moved tack signal wire still no change  tried 2 other  remotestart modules  no change  whats wrong ???
Posted By: moonliter
Date Posted: December 02, 2008 at 4:34 PM
Had you programmed the tach before you attempted to remote-start the first time ?
Date Posted: December 02, 2008 at 4:42 PM
ya  also tried 2 new remote start modules  with no change.
Date Posted: December 02, 2008 at 4:55 PM
I would do a system reset. Then of course, you need to reprogram the remotes again. Without tach wire connected, try remote start and see what happens
Date Posted: December 02, 2008 at 4:58 PM
will try that tomorrow. thanks  will post  what happens in the morning .
Posted By: lspker
Date Posted: December 02, 2008 at 9:42 PM
did you cut the yellow wire? (standard start select)
Date Posted: December 03, 2008 at 8:48 AM
unhooked tack wire  reset remote start module and programmed remotes and  pressed start button and envoy starts  fine every time without a tack wire learned  or hooked up.  why ?
Date Posted: December 03, 2008 at 10:42 AM
Why? b/c it is in tachless mode. autostart called it VTS. It is automatic and there is no tach to learn, it just monitors the engine starting sequence & release the starter at the right time after the engine is started. This test is just to prove that there wasn't anything wrong with the module. Your original problem was the tach which probably not hooked up to the right tach wire in the vehicle. Where did you hook up the tach wire to ?
For your case I still suggest you connect the tach wire, tachless mode can be a problem during very cold weather.
Posted By: kgerry
Date Posted: December 03, 2008 at 3:09 PM
your starter likely has a tachless setting...,. this vehicle has factory anti-grind so i always program for voltage sense-long crank anyway....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: lsondubz
Date Posted: December 05, 2008 at 7:41 AM
Are the 2008s different than earlier years. Ive done plenty of 04-06 Trailblazer/Envoys but had someone asking about an 08?
Posted By: corlon
Date Posted: December 12, 2008 at 11:57 PM
i'm working on a 2008 chev trailblazer for remote start. everything works fine except the theft light stays on until i put the key close to the ign cylinder. the key has a chip in it. it says pk3. does anyone know of a bypass for transponder on a 2008 chev trailblazer?
nice...
