2008 lexus es 350 door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=109477
Printed Date: May 11, 2026 at 8:12 AM
Topic: 2008 lexus es 350 door locks
Posted By: northern
Subject: 2008 lexus es 350 door locks
Date Posted: December 04, 2008 at 8:31 PM
Did a 2008 lexus ES 350 today with the push button start. I can't find the door lock wires on the vehicle. I spent a few hours looking for them. I went into the door switch, there are only 6 wires there and none of them test the way they should.
Astrostart and autostart wiring diagram say purple and Brown for lock/unlock (in the kick or BECM). The description that they give is also not right(26pin connect...ect..) Anyone have a better idea on this vehicle? Ive done hundreds of autostarts but never so much of a problem finding the locks.
Posted By: mikvot
Date Posted: December 04, 2008 at 10:28 PM
My info says the same as yours. Did you find a violet or brown wire at all? If so, are you testing the wires with the key in the door lock cylinder.
Posted By: northern
Date Posted: December 05, 2008 at 8:28 AM
This is a pushbutton vehicle. There is no Door lock(key) cylinder. There is a small hole below the handle but if you seperate the key from the smart key transmitter it does not go in that small hole.
Posted By: northern
Date Posted: December 08, 2008 at 8:56 PM
Anyone?
Posted By: Chris Luongo
Date Posted: December 08, 2008 at 11:39 PM
After you get the door panel off, at the back edge of the door there's like maybe a 6-pin plug, with the wires running toward the front of the door......the lock/unlock wires are in there for sure.
To test them, you have to remove the decorative key-cylinder cover from the outside of the door. You put the car's metal key into that slot, and then pry the cover off, and then it's a key cylinder there like any regular car.
