2003 volkswagon passat remote start chart
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=109504
Printed Date: May 20, 2026 at 9:50 PM
Topic: 2003 volkswagon passat remote start chart
Posted By: criego
Subject: 2003 volkswagon passat remote start chart
Date Posted: December 05, 2008 at 3:20 PM
Can Any one help me out with a wiring chart for a 2003 Passat remote start and bypass. Thanks Alot
Posted By: ckeeler
Date Posted: December 05, 2008 at 8:17 PM
| 12 VOLT CONSTANT | RED (+) | IGNTION SWITCH HARNESS | | | STARTER | RED / BLACK (+) | IGNITION SWITCH HARNESS | | | STARTER 2 | N/A | | | | IGNITION 1 | BLACK (+) | IGNITION SWITCH HARNESS | | | IGNITION 2 | N/A | | | | IGNITION 3 | N/A | | | | ACCESSORY /HEATER BLOWER 1 | YELLOW/BLACK (+) | IGNITION SWITCH HARNESS | | | ACCESSORY /HEATER BLOWER 2 | N/A | | | | KEYSENSE | N/A | | | | PARKING LIGHTS ( - ) | N/A | | | | PARKING LIGHTS ( + ) | GREEN/ RED (+) | @ HEADLIGHT SWITCH | | | POWER LOCK | RED / GREEN (TYPE B) | @ DRIVERS DOOR MODULE, See NOTE *1 | | | POWER UNLOCK | RED / BLUE (TYPE B) (Requires Double Pulse) | @ DRIVERS DOOR MODULE, See NOTE *1 | | | LOCK MOTOR WIRE | BLACK/ BLUE (+) | @ DRIVERS DOOR MODULE, See NOTE *1 | | | DOOR TRIGGER | BROWN / YELLOW (-) | @ COMFORT Module, 23-Pin Plug, Pin 1, See NOTE *2 | | | DOMELIGHT SUPERVISION | BLUE/GRAY (-) | @ COMFORT Module, 23-Pin Plug, Pin 21, See NOTE *2 | | | TRUNK RELEASE | BROWN / GREY to BROWN / GREEN | @ COMFORT Module, 23-Pin Plug, Pin 2, See NOTE *2 | | | SLIDING POWER DOOR | N/A | | | | HORN | BLACK / YELLOW (+) (Alarm Horn) | @ COMFORT Module, 15-Pin Plug, Pin 11, See NOTE *2 | | | TACH | Any wire NOT BLACK/ BLUE or GREEN/ RED | @ ANY FUEL-INJECTOR | | | WAIT TO START LIGHT | N/A | | | | BRAKE | RED / BLACK (+) | @ SWITCH ABOVE BRAKE PEDAL | | | FACTORY ALARM DISARM | DISARMS WITH UNLOCK, First Pulse Disarms | | | | ANTI-THEFT | TRANSPONDER ANTI-THEFT SYSTEM, REQUIRES BYPASS MODULE AND EXTRA IGNITION KEY | TRANSPONDER @ IGNITION SWITCH TUMBLER | |
| NOTES | NOTE *1 the DRIVERS DOOR MODULE is located INSIDE the DRIVERS DOOR.
NOTE *2 the COMFORT MODULE is UNDER the CARPET in FRONT of the DRIVERS SEAT in a PROTECTIVE BOX. |
