2006 jeep liberty bypass problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=109637
Printed Date: April 03, 2026 at 1:43 PM
Topic: 2006 jeep liberty bypass problem
Posted By: Memphisman
Subject: 2006 jeep liberty bypass problem
Date Posted: December 10, 2008 at 8:41 PM
I just installed a Crimestopper RS-1 remote starter in a 2006 Liberty using a CH-TBU.2 bypass. The bypass programmed up properly and works if you hold it up to the ignition switch and try the RS, but it will not work if I use the loop that comes with it. I checked and it's getting power and the ground out when running is working properly. I have tried everyway that I can think of to wrap the wire loop around the ignition. Anybody of a "sweet spot" that this vehicle likes (I'm having the same issue with a 2005 Pacifica)?
Posted By: jseibold
Date Posted: December 15, 2008 at 9:54 PM
I've found the sweet spot.  make sure you put the loop in front of the antenna ring, not around it.  I usually use a hot glue gun to hold it in place.  should solve your problem-good luck
Date Posted: December 16, 2008 at 7:09 AM
Thanks for the tip. I'll give it a shot.
