multiplex wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=10984
Printed Date: April 24, 2026 at 9:52 AM
Topic: multiplex wiring
Posted By: source
Subject: multiplex wiring
Date Posted: March 16, 2003 at 3:43 PM
just a quick question about new europeion vehicles which have multiplex wiring used in them. does anybody know of a programable reciver and transmiter which could be used to help overcome this problem
thankyou
source
Posted By: Car-Stuff
Date Posted: March 16, 2003 at 4:01 PM
You've got me confused...what is it you are trying to do??
Most vehicles can have systems installed to them, you may need to use resistors for different functions though.
Can you elaborate for us.
Nick
Posted By: Jussi
Date Posted: March 16, 2003 at 4:14 PM
I think that "source" means that CAN-stuff...
JL
Installer/Owner
JL-Autosound
Helsinki, FINLAND
Posted By: source
Date Posted: March 16, 2003 at 4:40 PM
in some of the vehicles that we work on in thr uk we are finding that there are more vehicles coming out with multiplex wiring this is when data is sent through cables not just pos or neg or various voltages,
example: mitsubushi galant evo7 electric window lift
there are only five wires going to the switch assembly and it controls 4 windows and the window lock
i have also been told that if you take the moter out of the drivers door and put it in any other door it would only operate if it sees the multiplex pulse from the drivers door switch so all the moters see the pulse but only work when they get the right code
they say that it cuts down on unnessesery cables and weight
can anyone help
Posted By: draasch
Date Posted: March 16, 2003 at 8:52 PM
i dont know everyone else but i'm going to go back to the basics..........a bike.
much easier to work on. lol
david
Posted By: jrilla
Date Posted: March 16, 2003 at 9:28 PM
There are modules that are called databus interface modules that control many of the features you are talking about. take a look at www.bypasskit.com and they will have almost all of the available kits that have been made this far. They dont have one for the mitsubishi windows yet though. You may be able to grab the wires for the rest of the windows under the dash though.
J Rilla
Owner/Installer
Date Posted: March 17, 2003 at 2:34 PM
A multiplex system does not normally carry a code. The voltage on the wire is different for different functions.
You must ascertain the resister value to replicate the function. The circuit to be tested must be disconnected from the load when testing the resistor value.
Nick
